Anthony Appleyard opened this issue on Jan 12, 2019 ยท 4 posts
Anthony Appleyard posted Sat, 12 January 2019 at 6:48 AM
See https://www.daz3d.com/karma-870-magnetic-accelerator-set
This is a 2-hand-held gun called a KARMA-870 Magnetic Accelerator. It is for DAZ Studioo.
Does it contain the geometry as .obj ?
If not, is there any way to adapt it for Poser?
SilentWinter posted Mon, 14 January 2019 at 6:09 PM
One option is to download the free daz studio, then open the prop in there and export as .obj I'm not sure if the DSON importer for Poser works with this kind of thing or not (Sorry, I don't use Poser).
FlagonsWorkshop posted Wed, 30 January 2019 at 2:19 PM
That one is all .dsf files so yes, you'd have to do an export of some sort to use it. I don't think it can be natively used in poser. It does not contain geometry in .obj format as it stands.
Glitterati3D posted Mon, 04 March 2019 at 4:49 PM
I convert DAZ models to Poser. I use Dimension3D's DSF Toolbox to export an object file from the .dsf file, then rig and texture in Poser. In most cases you can use the vendor's texture files which are in the same place as Poser's - Runtime>Textures. Today I grabbed DM's Vertigo on sale and converted all the props. In that case, most of the textures were DS shaders, but I just used Vince Banga's Superfly Shaders on the set easily for Poser. A test render I did this afternoon:
