moldie opened this issue on May 12, 2001 ยท 7 posts
moldie posted Sat, 12 May 2001 at 2:43 AM
JeffH posted Sat, 12 May 2001 at 2:46 AM
Use anti-alias in the render options.
RealitysPoison posted Sat, 12 May 2001 at 8:15 AM
Or do you mean where the texture 'slid' at the nipple? Was this rendered? I have had that problem before where the nipple wants to run across the chest, but that was only when I was working. When I rendered the scene, it placed just fine.
Jim Burton posted Sat, 12 May 2001 at 9:09 AM
Check the nipple material, if not set to white it will conflict with the map, especially if the map isn't regestered well in that area.
moldie posted Sat, 12 May 2001 at 11:42 AM
Its rendered, and set to white. I'm still haveving the problem.
black-canary posted Sat, 12 May 2001 at 5:50 PM
there's a pretty distinct ring around the right areola...it sure looks like it's not set to white. But the texture also may have a problem with the nipple placement on the right side. Is this a custom texture?
moldie posted Sat, 12 May 2001 at 9:09 PM
Yes, but I chose it to show to you guys because areolas were rounder than most of them. As I said, I am having trouble with every texture, including the original Millwoman texture Victoria came with.
