Vex opened this issue on Jan 29, 2019 ยท 18 posts
Vex posted Tue, 29 January 2019 at 10:35 AM
I'm not sure if this is intentional but I can't checkout with just La Femme in my cart.
Vex posted Tue, 29 January 2019 at 11:28 AM
Nevermind anyway. I won't be making any products for La Femme because Poser11 is honestly, a piece of crap software that needs to go to the graveyard.
Can't get zBrush to communicate, the 'support team' has already gone to the graveyard, so nevermind.
bwldrd posted Tue, 29 January 2019 at 12:00 PM
Well, hopefully someone from the marketplace will respond. There are a lot more of us who are dealing with the checkout problem also.
Consider me insane if you wish, but is your reality any better?
PrestonW posted Tue, 29 January 2019 at 12:17 PM
There is a minimum amount of $3.50 to checkout. There is nothing we can do to override that.
LaurieA posted Tue, 29 January 2019 at 12:36 PM
PrestonW posted at 1:34PM Tue, 29 January 2019 - #4344527
Then what you need to do is STOP calling the figure free and charge $3.50. Otherwise, it's false advertising. Simple. You are misleading people. Don't give us any BS about "there's nothing you can do". There is absolutely something you can do.
akura_ posted Tue, 29 January 2019 at 12:40 PM
wont let me get it for free ether. also i had the same issue before with another product and the price was fixed so i was able to buy it :3 it was 3.49 but was raised to 3.50 and i was able to purchase it. so how come the same cant be done with this product?
Khai-J-Bach posted Tue, 29 January 2019 at 12:58 PM
PrestonW posted at 6:58PM Tue, 29 January 2019 - #4344527
you know companies get fined for doing that? it's called "bait and switch"
casamerica posted Tue, 29 January 2019 at 1:17 PM
PrestonW posted at 2:10PM Tue, 29 January 2019 - #4344527
So, something as simple as placing it in the Free Stuff library is out of the question? I mean it is being touted as free. Is it free or is it $3.50? To be honest, I would have no objection to paying for it. I just do not like being told something is free when, in fact, it isn't. If you need to make a minimum purchase to get La Femme free, clearly state as such. Why create a PR problem with what should be a major product release?
DivabugDesigns posted Tue, 29 January 2019 at 1:26 PM
If it's a matter of how the checkout process is programmed, why can't it be full price or even $3.50 with a coupon that makes it free? This is frustrating.
Torquinox posted Tue, 29 January 2019 at 1:45 PM
The snag is the $3.50 minimum. You could buy another product for $3.50. Then you can slide her into the cart as a tagalong. It's not ideal, but it should work. Then you say, "Free with $3.50 purchase." Something like that.
FlagonsWorkshop posted Tue, 29 January 2019 at 1:47 PM
As a total outsider on the issue, I can't use her since I am a DAZ user, this issue is creating a lot of negative comments both here and over on the DAZ board. I wouldn't just let it slide, it is ruining a pretty fine promotional effort. Either create a temporary link to download the files like you do with the prime freebies, put her in the free section, or fix the cart. You can't afford not to respond to this problem.
LaurieA posted Tue, 29 January 2019 at 1:53 PM
I feel like Rendo botched the launch of this character for Dee, Gabe, Nerd and all the other folks that worked on her and/or made stuff for her. Redo your ad copy to include "btw, you gotta buy something for at least $3.50 before you can get her".
Miss B posted Tue, 29 January 2019 at 3:00 PM
Torquinox posted at 3:59PM Tue, 29 January 2019 - #4344563
That's exactly what DAZ3D has been doing in their store for years. That I can see, because then everyone has the "warning" ahead of time, instead of when they already have it in their cart and try to purchase it. This is very disappointing.
_______________
3-DArena posted Tue, 29 January 2019 at 3:42 PM
LaurieA posted at 3:40PM Tue, 29 January 2019 - #4344565
Actually they didn't botch it for those who made stuff for her - because if people were buying the other stuff and adding her to the cart there wouldn't be an issue. ;-)
That said it has come up before that $0.00 items should be marked "Free with purchase" or "Free with minimum purchase"
I'll probably grab her the next time I check out with something,just to have her.
3-D Arena | Instagram | Facebook
I do not feel obliged to believe that the same
God who has endowed us with sense, reason, and intellect has
intended us to forgo their use.
-Galileo
Moritz5 posted Tue, 29 January 2019 at 3:44 PM
If La Femme is free, then please move it to the Free Stuff area. This is a very important figure for Poser users. Please don't mess up the introduction this way.
Moritz5
Miss B posted Tue, 29 January 2019 at 6:39 PM
I think the only reason they didn't do that to begin with is, La Femme isn't going to be free forever. She will eventually be available for her full price. It's just up in the air for how long she'll be available for free.
_______________
3dcheapskate posted Wed, 30 January 2019 at 3:12 AM
PrestonW posted at 4:09PM Wed, 30 January 2019 - #4344527
Really ?
So how do you explain this - https://www.renderosity.com/mod/forumpro/?thread_id=2930748&#msg4344522 - an apparently successful 'purchase' of this item for $0.00?
Alternatively - what about moving it to the FreeStuff section temporarily?
The 3Dcheapskate* occasionally posts sensible stuff. Usually by accident.
And it usually uses Poser 11, with units set to inches. Except when it's using Poser 6 or PP2014, or when its units are set to PNU.
*also available in ShareCG, DAZ, and HiveWire3D flavours (the DeviantArt and CGBytes flavour have been discontinued).
Torquinox posted Wed, 30 January 2019 at 9:47 AM
I'm sure Miss B is right, the intro is a promo effort to build user base. By now, the cart glitch is known and reported with workarounds acknowledged. When a better solution emerges, cheers to that. Meanwhile, best bet is to buy something you want and add the free thing to the cart.
