Subject: LaFemme crashing Poser 11 Pro?
gwp opened this issue on Feb 07, 2019 ยท 8 posts
gwp posted Thu, 07 February 2019 at 5:53 PM
Is anyone else having problems with Poser 11 Pro crashing while using LaFemme? After this happened several times I installed the latest update for Poser 11 Pro but still had a crash occur after I applied a V4 pose to LaFemme (which worked fine except for the feet) and then tried to adjust the feet. No one else has mentioned crashes, so I am trying to figure out what is going wrong for me.
randym77 posted Thu, 07 February 2019 at 8:39 PM Online Now!
I'm not having any problems. I've applied V4 and Dawn poses to LaFemme, with no crashes.
DCArt posted Thu, 07 February 2019 at 9:00 PM
It sounds like you might have IK on, if the poses are working on everything but the feet and then you try to adjust the feet. Choose Figure > Use Inverse Kinematics and then uncheck both feet. The poses should work better after that and you'll also be able to move the feet more easily.
hborre posted Thu, 07 February 2019 at 9:12 PM
I haven't had any crashes with IK on while posing La Femme. However, her feet still don't cooperate with V4 poses.
randym77 posted Thu, 07 February 2019 at 9:28 PM Online Now!
No crashes with IK on for me, either. And the feet look pretty good, with IK or not. It's the hands that can look kind of odd.
A_Sunbeam posted Fri, 08 February 2019 at 1:29 AM
Every now and again double-clicking doesn't select an item in the library when I've got a LaFemme character. Dragging an item to conform also doesn't work, or selecting a light. I have to exit poser and open the file again to get it working correctly. And there have been a couple of freezes needing a force quit. (iMac)
infinity10 posted Fri, 08 February 2019 at 4:36 AM Online Now!
I think it is because nVidia just released an update for the graphics driver and you need to install that for Poser to work properly ??
Eternal Hobbyist
Boni posted Fri, 08 February 2019 at 6:40 AM
Just as an added side note ... Universal Poses are not recommended for La Femme. Otherwise, I haven't had any issues with V4 poses and La Femme.
Boni
