Forum: MarketPlace Customers
Subject: What rights do the models come with?
map84 opened this issue on Feb 09, 2019 ยท 8 posts
map84 posted Sat, 09 February 2019 at 10:02 AM
Hi, on rival 3d sites they usually say what you can and can't do with each model you purchase,,I can't find this info on the models pages here, any help would be great! Thanks, Mark.
hborre posted Sat, 09 February 2019 at 10:57 AM
Usually, that is spelled out in the readme file which should be linked on the product page.
PrestonW posted Sat, 09 February 2019 at 11:01 AM
Here are some links that may help you.
Standard License
Extended License
map84 posted Sat, 09 February 2019 at 2:36 PM
PrestonW posted at 2:36PM Sat, 09 February 2019 - #4345698
Standard License
Extended License
Very kind, thanks for both replies.
Torquinox posted Wed, 13 February 2019 at 11:35 AM
This reminds me of a related question I had: The Standard License covers commercial and not-commercial 2d-renders of the licensed item(s). To use the actual mesh in a product, we must use extended license, encryption, etc to protect the item from being removed, reverse-engineered and redistributed. Is it OK on standard license to make 2d rendered sprites of the item for use in some sort of interactive product or presentation? No mesh, no textures, no part of actual item is embedded in the product, strictly 2d rendered sprites derived from the item's permitted use under standard license.
FlagonsWorkshop posted Wed, 13 February 2019 at 1:21 PM
I asked that over on DAZ and 2D Sprites were fine under the standard license. You had all the rights to use your render as you pleased. Of course this place isn't DAZ ;)
Torquinox posted Wed, 13 February 2019 at 2:03 PM
That's good to know. Thanks @FlagonsWorkshop! Hopefully Jenn or Preston will stop by soon and answer for Rendo. :)
Torquinox posted Thu, 14 February 2019 at 8:31 PM
I used sitemail and received a reply from Jenn. I quote,
Yes, that is allowed. ? 2D rendered images and even animations you post are fine as the viewers have no way to obtain the obj or other proprietary information from the models/products.
That's good news. Thank you, Jenn!
