Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Subject: Problems conforming to V4 figure and non working morphs
thartwick1 opened this issue on Feb 15, 2019 ยท 3 posts
thartwick1 posted Fri, 15 February 2019 at 7:54 PM
So I'm having a problem sometimes when I try to fit an outfit to a figure. If I go to the article of clothing and select its body morph and try to use any of the morphs (ex. voluptuous), it will not work or when it does work, it will change the V4 figure. Can anyone tell me what's going on?
Thanks in advance for any insight.
hborre posted Fri, 15 February 2019 at 8:15 PM
Conforming clothes responds to the figure's morphs and usually not the other way around. So if you want voluptuous as your figure morph, you dial the morph for V4 and the clothing should conform along with her. However, the morph present in the figure should exist in the clothing also, otherwise, you will only see changes in the figure and not the clothes. If you dial morphs in conforming clothes, V4 will respond to those changes, but that is not the way it is intended to work.
thartwick1 posted Sat, 16 February 2019 at 10:47 AM
Thanks for the explanation. I had a misconception on how the morphs worked.
