Subject: Apply "Drop to Ground" to all keyframes?
tankman opened this issue on Mar 17, 2019 ยท 4 posts
tankman posted Sun, 17 March 2019 at 10:42 PM
Hi. I am applying an animation to a figure, but it removes my "Drop figure to ground" (Command-D) operation. Is there a way to apply that operation to every frame without advancing one frame and hitting command D over and over again - it gets quite tedious ;)
Thanks -Amanda
operaguy posted Sun, 17 March 2019 at 11:27 PM
There is a utility script for that! Specifically. I've used it.
scripts:utility:dropActToFloorAllFrames
::::: Opera :::::
tankman posted Mon, 18 March 2019 at 9:16 PM
Thanks for the tip. It works great ?
Richard60 posted Mon, 18 March 2019 at 9:17 PM
The other option is to put in a new layer and adjust the Y translate for the body of the figure down. Make the keyframe a constant and all frames will drop by the same amount.
The advantage is that if your animation has a jump it won't be flatten by dropping to ground.
