Forum: Vue
Subject: Recommends on setup of pcs for rendering
rolffimages opened this issue on Apr 04, 2019 ยท 7 posts
rolffimages posted Thu, 04 April 2019 at 8:29 PM
Hey folks. I am looking for recommends for setting up 3 PCs for rendering. The PCs stats below. PC 1: Win 10 pro 64 BIT, i73630QM CPU@ 2.40 GHz, 16GB RAM PC 2: WIN 10 PRO 64 BIT, 2 PROCESSORS INTEL XEON 6PU E5-2620 V4 @ 2.10 GHz, 32 GB RAM PC 3: WIN 7 PRO 64 BIT, AMD PHENOM IIX3710 2.6 GHz, 8 GB RAM
rolffimages posted Fri, 05 April 2019 at 3:38 PM
Let me add this little bit. What i am seeking recommends for is how would you set these up for network renders? Which would you use as the main PC and which would be the render cows.
famekrafts posted Mon, 10 June 2019 at 10:23 AM
Bump Any help here, even I am interested to set up a mini render farm, but have no clue which will work with Vue 2014 and how to set it up?
kenmo posted Mon, 17 June 2019 at 9:52 PM
I do some network rendering with Vue. I use my most powerful computer(I7-4770) as the main Vue computer and the lesser PCs as render nnodes (I5-2500K & AMD 8320)
famekrafts posted Mon, 17 June 2019 at 11:42 PM
kenmo posted at 11:42PM Mon, 17 June 2019 - #4353344
Can you guide us how to setup the machines?
kenmo posted Thu, 27 June 2019 at 9:37 PM
The first thing is to find the rendercow setup on your install CD and then install rendercow onto the two other computers that do not have Vue installed onto them.
famekrafts posted Thu, 27 June 2019 at 10:44 PM
Well never had the install cd, I downloaded the software from the website directly. So basically render cow is installed, then what next, how do we connect the computers together?
