3Dream opened this issue on Apr 25, 2019 ยท 8 posts
3Dream posted Thu, 25 April 2019 at 3:26 AM
If you want to do a 3D image in Facebook using Poser you will need 2 images.
The first image is the normal render and the second image is the depth map.
NOTE: when you upload the 2 images in Facebook make sure to upload them at the same time in PNG format.
If you name the first image as picture.png, the depth map will have the following name: picture_depth.png
BTW, in a scene with several figures, I basicly change the value of the DepthCue_EndDist (Atmosphere) and after that I change the value of z (P) for a better contrast.You have to do some renders to get the best results as possible. I try to avoid figures and object that are located in negative Z positions because if I do that I will have to work with negative values in the DepthCue_StartDist and manage it with the DepthCue_EndDist will make you do a LOT of render tests before you get a nice result. I also notice that all the figures/object that are closer will be less contrasted but you must get the best depth as possible in all the scene. Take a look to the image I made.
Finally, I prefer to work with the Atmosphere because I get no problems with hair transparencies. As you can see in the depth map of the following image, the hair transparencies are correctly rendered.
STORE: https://www.renderosity.com/marketplace/vendors/3Dream
FREEBIES: https://www.renderosity.com/users/3Dream/freestuff
3Dream posted Thu, 25 April 2019 at 3:33 AM
You can see an example of a 3D image in Facebook here:
https://www.facebook.com/jose.silva.925059/posts/2153439684747469
And this is just a related video from Youtube:
https://www.youtube.com/watch?v=DInWVvfPQm8
Boni posted Thu, 25 April 2019 at 5:21 AM
What a great share! Thank you 3Dream!!! (love your La Femme mats by the way!!)
Boni
3Dream posted Thu, 25 April 2019 at 7:49 AM
Boni posted at 7:48AM Thu, 25 April 2019 - #4350672
Thank you very much Boni :)
Boni posted Thu, 25 April 2019 at 1:09 PM
See we can even rate a thread here ... as well as fb!!
Boni
3Dream posted Fri, 26 April 2019 at 1:52 PM
My last 3D version in Facebook of a Poser render with La Femme: https://www.facebook.com/jose.silva.925059/posts/2156962381061866
3Dream posted Sat, 27 April 2019 at 4:43 AM
Just to show you a small preview of the maps that I did for the 3D image (link in the previous comment).
HandspanStudios posted Sun, 02 June 2019 at 11:38 PM
That really looks fantastic!
"Your work is to keep cranking the flywheel that turns the gears
that spin the belt in the engine of belief that keeps you and your
desk in midair."
Annie Dillard
