Subject: Cycles SSS skin and Branched Path Tracing?
Afrodite-Ohki opened this issue on Jun 05, 2019 ยท 5 posts
Afrodite-Ohki posted Wed, 05 June 2019 at 8:28 AM
So, I got reported a problem with my already released character set.
Here's the Superfly version of her skin shader (External outputs plugged to Cycles root, External inputs plugged to diffuse, bump and spec maps): image.png
I've been testing her always with Branched Path Tracing off and Progressive Refinement on, as that works best for me and I thought the only difference in those were render times and quality in specific things. However, a customer of mine uses Branched Path Tracing on. Here's my trouble.
Branched Path Tracing off: image.png
Branched Path Tracing on: image.png
The only difference I could get was if I turn Volume Samples higher: image.png
What gives? Is there anything I can tell my customer to do without me having to change her shaders (as this is an already released product)?
Feel free to call me Ohki!
Afrodite-Ohki posted Wed, 05 June 2019 at 11:24 AM
Answered in the Smith Micro forum. Thanks!
Boni posted Wed, 05 June 2019 at 1:43 PM
AS a courtesy, could you relay the answer here for those following this thread?
Boni
Afrodite-Ohki posted Wed, 05 June 2019 at 2:53 PM
Sure! The Scatter Volume node shouldn't be there - I used it because I'd seen a skin shader with it from years ago, and started adding more nodes to get the look I wanted. Turns out the node wasn't even being rendered with Branched Path Tracing off to begin with, for some reason - so the rest of the shader was responsible for the entire look I wanted, and the Scatter Volume was causing all that weird redness/blackness with Branched Path Tracing. I just deleted that node and everything worked.
More details, and some tips for the SubsurfaceScattering node, on the thread I was given this answer: https://forum.smithmicro.com/topic/9665/cycles-sss-skin-and-branched-path-tracing/14
Boni posted Wed, 05 June 2019 at 4:04 PM
Boni
