EdW opened this issue on Jul 18, 2019 ยท 7 posts
EdW posted Thu, 18 July 2019 at 11:37 AM
This is weird, but for whatever reason the morphs to open and close V4 eyes aren't working. Every other morph seems to be working fine. I've tried to readd the base morphs.. Nothing works... Any ideas?
PenelopeFlynn posted Thu, 18 July 2019 at 11:52 AM
Did you check to see if you have one V4 superimposed over another where you might be changing the eyes on the head of the character underneath and therefore not seeing the change on the character on top? This has happened to me before, so...
Nails60 posted Thu, 18 July 2019 at 12:04 PM
This is a well known problem with V4. It's been discussed in the DAZ forums and the Cgbytes forums. I picked up an injection pose at the Cgbytes forum which fixes it, but there is another way involving changing a parameter in the DAZ files. I can't remember the details but if you search those forums you should find the answer.
EdW posted Thu, 18 July 2019 at 12:13 PM
Thanks for the quick responses. I can't access the DAZ forums.. All I get is a blank page there
Morkonan posted Thu, 18 July 2019 at 9:50 PM
There are two ways to fix the problem.
The first is simply running one's V4 install/register exe that's going to be in the Poser runtime directory, under Daz something, where v4 was installed. No reregistration necessary, just click the exe/bat file for v4 to get it to reregister the file settings.
The second is easier - Go to your V4 directory and reapply the basic poses and/or the expansion whatsits - Whichever has the eye dial morph thing, I forget.
One of these ways WILL WORK unless you've gone to extreme pains to bork up your own V4 CR2 and/or have a very borked up custom character. :)
samsiahaija posted Fri, 19 July 2019 at 9:20 AM
Everything works fine for me (V4.2: Poser 11.1.1 Standard, Win 7 Pro 64)
an0malaus posted Sat, 20 July 2019 at 12:40 AM
Lots of good answers in this thread. For reference, here's a link to the recent SM Forum discussion on the problem, which contains links to several fixes, as well as useful discussion of the reason for the problem and a plethora of ways to fix it, so it never happens again (which can take quite a bit of work, if V4 figures have been saved back to the library with corrupted valueOperations for the eyelid open/close parameters).
