Audierne opened this issue on Jul 26, 2019 · 8 posts
Audierne posted Fri, 26 July 2019 at 9:41 AM
Hi. I recently started using Studio 4.11. Genesis 8 Female eyes render fine, but am having the above problem with Genesis 8 Male. I have not changed any settings, it's a new install. This spot render uses the base materials (3Ddelight or whatever, but the same happens with Iray). Can anybody advise how to fix the problem.materials.
thanks, Pete
jestmart posted Sat, 27 July 2019 at 8:07 AM
Load a G8F with eyes that work and compare the surface settings with G8M.
RHaseltine posted Sat, 27 July 2019 at 9:15 AM
Is the figure away from the origin?
Audierne posted Sat, 27 July 2019 at 4:17 PM
Thank-you for responding. No, it is in the original place, original pose etc as loaded. Not moved at all. I have just tried again on a freshly loaded / unmoved etc. figure and the result is the same.
Edited to add - Windows 10, up-to-date with releases etc.
Audierne posted Sun, 28 July 2019 at 6:47 AM
A bit of experimenting. Loaded the base figure and spot rendered, eyes look OK. Then clicked on materials and the eyes looked as in my attached screen shot. Tried adding materials again etc. but the eyes still render as per attached screenshot. It seems that the eyes render OK on the figure as first loaded, but then 'adding the materials' (which is how the Gen 8 Female works - I think, now I'm beginning to doubt my sanity) causes the problem. Seems rather odd. Getting confused...…
Audierne posted Sun, 28 July 2019 at 8:30 AM
Please ignore above comment - I got that completely wrong - sorry. Loaded base figure and spot rendered - produces 'reasonable eyes' i.e. not with the blank brown look. Then added mats and rendered - this time getting the same result as shown in the screen-shot. Other genesis figures are fine, it just seems to be a problem with the Genesis 8 Male mats for the eyes.
Roland58 posted Sun, 25 August 2019 at 9:42 AM
Same for me. My solution is simple, I just copy irises suface and paste on eyemoisture
Audierne posted Thu, 12 September 2019 at 5:36 AM
@ Roland58
thank-you!
