Forum: DAZ|Studio
Subject: DPI Setting
borgking001a opened this issue on Aug 17, 2019 ยท 5 posts
borgking001a posted Sat, 17 August 2019 at 2:26 PM
Right now, all of my Daz 3D renders are at 96 dpi, how do I increase the dpi for my renders?
RHaseltine posted Sat, 17 August 2019 at 3:21 PM
DS renders do nor have a PPI value assigned - your editor/viewer will probably assign one, either 96 or 72 according to the software/preferences. Remember that PPI is just a number at the front of the file - an render 1,000 pixels square at 300PPI is exactly the same as an image 1,000 pixels square at 96PPI. If you need an image of a set physical size at a set PPI just type the numbers as a sum - e.g. for a 6" by 4" image at 300PPI type 6 * 300 and 4 * 300 into the size fields.
borgking001a posted Sat, 17 August 2019 at 4:43 PM
I need dpi not ppi.
Deacon215 posted Sat, 17 August 2019 at 7:05 PM
Explanation of the difference.
https://99designs.com/blog/tips/ppi-vs-dpi-whats-the-difference/
per the article, exporting at 300 ppi is considered industry standard.
Connatic posted Mon, 23 September 2019 at 2:50 PM
DPI is a printer characteristic. A given printer will use a grid of dots to interpret a single pixel. I use an Epson SureColor P800, which does 2880x1440 dpi. The optimum ppi is 360.
