Subject: How to make clothing unselectable?
evanhem opened this issue on Aug 21, 2019 ยท 7 posts
evanhem posted Wed, 21 August 2019 at 10:54 AM
I never want to modify the clothing. Ever. How do I make it unselectable? I only want to be able to change joint angles of the body.
SeanMartin posted Wed, 21 August 2019 at 11:12 AM
If I"m understanding you correctly, just go to the Objects menu, go down to "Lock", and hit it.
docandraider.com -- the collected cartoons of Doc and Raider
randym77 posted Wed, 21 August 2019 at 11:30 AM
What I usually do is make the clothing invisible. The Hierarchy Editor lets you make figures, clothing, props, etc. invisible. (Click the little eye to toggle visibility on and off.) You won't accidentally grab something that's been made invisible this way.
quietrob posted Wed, 21 August 2019 at 11:39 AM
Hmm, I think Locking the the object (or body part) won't do it. I'm not sure that's possible besides hiding the clothing so it cant be selected, move your joint, and then making the clothing visible.
SeanMartin posted Wed, 21 August 2019 at 7:57 PM
quietrob posted at 8:57PM Wed, 21 August 2019 - #4359995
Except that, even when invisible, the clothing will still move. What are you trying to accomplish here?
quietrob posted Wed, 21 August 2019 at 9:45 PM
SeanMartin posted at 7:43PM Wed, 21 August 2019 - #4360067
Hmm, the OP said 'modify' not move. I think the OP needs to be a bit more clear.
EClark1894 posted Thu, 22 August 2019 at 7:34 AM
Why not modify the figure as you need, pose, and then just add the clothing? If it's conforming, then it should just snap right in place. No fuss, no muss.
