uncle808us opened this issue on Aug 27, 2019 · 7 posts
uncle808us posted Tue, 27 August 2019 at 12:20 PM
There are a lot of files in the download manager are the all necessary to run Poser pro 11? Do I have to download them all? Trying to save space on my old computer. Thanks
MacBook Pro OSX El Capitan Ver 10.11.6
jennblake posted Tue, 27 August 2019 at 2:38 PM
Hi.
You are only required to install the Poser.exe and the support files. You will need the human figures ONLY as you want. And if you use the faceroom you will need at least one of those installed. But they are not required.
uncle808us posted Tue, 27 August 2019 at 4:06 PM
jennblake posted at 5:04PM Tue, 27 August 2019 - #4360565
Hi.
You are only required to install the Poser.exe and the support files. You will need the human figures ONLY as you want. And if you use the faceroom you will need at least one of those installed. But they are not required. Thanks I ‘m on a Mac so I don’t think there is a.exe file. But what do yo mean by “the support files.” Thank you
jennblake posted Tue, 27 August 2019 at 4:41 PM
On the download manager..when you have the list of files to download and install you should see Poser and down in the list you should see Poser Support Files. Those should also be installed.
uncle808us posted Tue, 27 August 2019 at 10:26 PM
Got it installed and it's all working. Thank you.
jennblake posted Wed, 28 August 2019 at 9:02 AM
Welcome.
ypvs posted Wed, 28 August 2019 at 6:51 PM
If room is very tight then you can get away with installing only the main Poser file. A downside is the User Manual PDF is in the support files. You cannot add them in isolation you must re-install Poser at the same time. I've not found a download for the P11 manual PDF- can this be made available here (serial number required)?
Poser 11 , 180Gb in 8 Runtimes, PaintShop Pro 9
Intel Q9550 Quad Core cpu, 16Gb RAM, 250Gb + 250Gb +160Gb HD, GeForce GTX 1060
