Subject: Poser manual?
anniemation opened this issue on Sep 03, 2019 ยท 9 posts
anniemation posted Tue, 03 September 2019 at 2:23 PM
Is there a copy around? I need to figure out how to change the center point of a prop and moving the red and green things isn't changing anything. The link from the old Smith Mirco forum is down.
hborre posted Tue, 03 September 2019 at 2:47 PM
Under Help in the Toolbar, Poser Reference Manual.
anniemation posted Tue, 03 September 2019 at 2:53 PM
This is what I'm getting: file:///C:/Program%20Files/Smith%20Micro/Poser%2011/Poser%20Reference%20Manual.pdf I go there and it's only one page.
SamTherapy posted Tue, 03 September 2019 at 3:12 PM
I see a reinstall in your future. Never, ever, under any circumstances should you install Poser to Program Files. You should be able to call up the manual from within Poser without having to go anywhere but I'm guessing yours isn't working right because of where you installed the app.
anniemation posted Tue, 03 September 2019 at 3:17 PM
I'm waiting on the Renderosity version.
adzan posted Tue, 03 September 2019 at 3:34 PM
Hi. I think the one page pdf shows up when the support files haven't been installed correctly.
the Poser Reference Manual.pdf should be in the Documentation folder - if it isn't there you will need to re-install the - Poser Support Files for Poser from the Download Manager
randym77 posted Tue, 03 September 2019 at 3:38 PM
It's supposed to be in
C:UsersPublicDocumentsPoser 11 ContentDocumentation
if you installed it.
EClark1894 posted Tue, 03 September 2019 at 3:49 PM
Actually, there are two pdf files. One is in Program files and is only one page long. The reference manual, which is the one you want is in the C:Users/Public/Documents/Poser 11 Content/ Documentation. So no, you probably don't need a re-install. I found this out the hard way.
quietrob posted Tue, 03 September 2019 at 6:32 PM
And thanks to this thread, I didn't need to find it via the hard way. Thanks Earl, Randy and Adzan. @anniemation, It will take a while for them to scrub every last vistage of Smith-Micro from the books and to set up updates, and other surprises that I won't reveal. Heh, Heh, I can feel the tension in the air over at that place that shall not be named.
