Forum Coordinators: Kalypso
Carrara F.A.Q (Last Updated: 2024 Nov 28 3:44 pm)
Visit the Carrara Gallery here.
if your animation is more frames than the animated shader.
in the sequence, drag marquee around the shader's keyframes, use the Do button to "repeat"
been experimenting with keyframing the diffuse color chanel. trick was how to save it as a preset. saving it purely as a shader file didn't work, it only applies the 1st frame
added animated shader to free stuff
shader is attached to a cube porimitive drag in the cube to bring in the shader to your scene. apply shader to the surface desired then delete the cube
was thinking for a holiday scene
