PenelopeFlynn opened this issue on Oct 10, 2019 ยท 11 posts
PenelopeFlynn posted Thu, 10 October 2019 at 4:46 PM
After freezing a few times Poser Crashed. I cannot get it to open or do anything for that matter but give me this message:
I am obviously online so why am I getting this?
I am running Windows 10, 64 bit system, i7, 32G Ram. Thanks in advance for any assistance.
Nails60 posted Thu, 10 October 2019 at 4:57 PM
Which version of poser are you using? If using poser11, 11pro or 2014game dev have you upgraded to 11.2, a free upgrade?
Boni posted Thu, 10 October 2019 at 4:59 PM
Have you updated to the new upgrade so Poser will redirect to Bondware as it's new server? IF not, Bondware (Renderostiy) is the new owner of Poser and please go to: Poser Home Page
Please feel free to come here or to the official Poser Forum to learn all the information you need about the downloads ... and the wonderful NEW free content that comes with it.
Boni
hborre posted Thu, 10 October 2019 at 5:01 PM
Poser has changed hands, it is no longer the property of Smith-Micro. It is now the property of Bondware/Renderosity. In order to get a working copy, you will need to download the free update from https://www.posersoftware.com/downloads. You will need both Install Poser.exe and support files to get started. If you have customized your Poser in any way, make sure that during the installation, select use existing preferences to preserve those changes. If you have your SN handy, download the extra content. Otherwise, you should be able to obtain it through Poser.
PenelopeFlynn posted Thu, 10 October 2019 at 5:14 PM
Yes. I had the 11.2.291 update. This is what crashed. I gather then that I should reinstall it.
PenelopeFlynn posted Thu, 10 October 2019 at 7:13 PM
Okay, so I'v reinstalled twice and gotten the same message. I checked the programs in Control Panel and noticed that my Poser 2014 is still there would that make a difference. Also should I uninstall all versions of Poser from the Control Panel before attempting to reinstall?
hborre posted Thu, 10 October 2019 at 8:07 PM
If you previously own Poser 2014, it is not part of the update deal. Only Poser 11, Poser 11 Pro, and Poser 2014 Game Developer are eligible for updating/upgrading. Your Poser 2014 has a permanent license and it is not affected by the Smith-Micro/Bondware transition. I have both Poser 11 Pro and Poser Pro 2014 on my computer and only the Poser 11 Pro is updated. Please verify that you indeed own Poser 11, otherwise, you will need purchase an upgrade to your Poser 2014.
structure posted Thu, 10 October 2019 at 8:08 PM Forum Coordinator
Penelope, try using geek uninstaller to uninstall - poser 2014 should not interfere with P11. then try reinstalling - sitemail me if the problem persists.
Locked Out
PenelopeFlynn posted Thu, 10 October 2019 at 8:36 PM
structure posted at 8:36PM Thu, 10 October 2019 - #4366685
I will. Thank you!
PenelopeFlynn posted Fri, 11 October 2019 at 8:00 PM
structure posted at 7:56PM Fri, 11 October 2019 - #4366685
Thank you so much. I used the uninstaller and took off Poser 2014 and Poser Pro 11 and its update then reinstalled it. Everything is back on track!
structure posted Fri, 11 October 2019 at 8:34 PM Forum Coordinator
PenelopeFlynn posted at 2:34AM Sat, 12 October 2019 - #4366851
Yw :)
Locked Out
