Forum: Carrara
Subject: an idea for converting poser weight maps to triax
MistyLaraCarrara opened this issue on Oct 28, 2019 ยท 2 posts
MistyLaraCarrara posted Mon, 28 October 2019 at 7:09 PM
if poser, ds, and carrara use the same color scheme in it's weightmapping
and if we knew the value of the color, a red for example. seeing red, yellow, green
and if we knew the value of that red poly
it should be as simple as a search and replace
a poser red value for a carrara red value
using a relational database would be simple for it swap the number.
the only program language i know is vba for access and excel. microsoft gives the access runtime engine for free. basically,
import a text file, swap numbers etc, output a report to a new text file, named with the appropriate file .extension .
thinking of making one that could do the blended or triax weight conversion,
examined a bunch of figure files,
so far the weight on each axis is the same exact numbers.
problem is, still need ds to uncompress files.
it is possible to call winzip or 7zip to run in a shell in the database.
while the rar trick works on car and cbr files, it doesn't work on duf or dsf files.
the dson editor automatically reads a compressed file, dunno how d3d did it. : kissing_heart:
At least the ds uncompress script can run on a whole folder theres also a batch script in ds to convert dsa to duf files, dsa material presets dont run in carrara, needs to be duf
headwax. posted Mon, 28 October 2019 at 7:15 PM
love your mind work Mysty, thank you!
