WilberPost opened this issue on Nov 01, 2019 ยท 4 posts
WilberPost posted Fri, 01 November 2019 at 9:21 AM
I'm having a RenderCow/HyperVue issue under Windows 10. I've been using RenderCow recently for the first time and when it works, it's great! The problem is that HyperVue only works reliably the first time following a reboot of my main (source) PC. Subsequent render jobs are "scheduled" but, HyperVue is often unresponsive and nothing happens, leaving a render job perpetually in the scheduled status.
One solution is to go into the Windows Task Manager and delete the running HyperVue process, then re-run the render from Vue. If I"m lucky, that restarts HyperVue and the render works, sometimes not. If that doesn't work, I have to reboot my PC and start the render again.
I've got workarounds, but they're annoying and time-consuming. Any suggestions? Thanks.
