Forum: New Poser Users Help
Subject: I need some help creating a prop. This should be easy!
DSQRD opened this issue on Nov 06, 2019 ยท 3 posts
DSQRD posted Wed, 06 November 2019 at 1:24 AM
I would like to create a room prop from the box primative found in poser. I first size, position and and texture 4 box props as walls and another box for the floor. Now how do I group these items together so that I can save them as a single room prop.in the Props library
Signed " I'm as stumped as Trump"
RedPhantom posted Wed, 06 November 2019 at 6:23 AM Online Now! Site Admin
If you want to keep them as separate pieces that load together, select one of the parts, then in the library, click on the plus. When the window pops up asking for a name, click on the select subset and select all the room parts you want saved together. You might want to parent them all to one part before saving for easy positioning later. I recommend this method as you can hide parts of the room as needed for posing.
If you want the room to become all one piece, files>export>obj select all the room parts and export them then file>import>obj and import the file. Then save it as a prop like above without using the subset button.
DSQRD posted Wed, 06 November 2019 at 3:23 PM
I knew it was simple, but I couldn't think of it. Thank you.
