romangirl opened this issue on Nov 15, 2019 ยท 5 posts
romangirl posted Fri, 15 November 2019 at 11:21 AM
Not so new.
A day or two ago, I lost one of the windows for the Pose Room (Poser 9). It's the window that allows me to clone, crop, paint, change colors, etc. I opened the instruction manual, but everything is garbled in notepad. I hope I don't have to reload Poser 9 and all of the updates. I keep searching the Pose Room but can't find it. I've checked Window, Object, Display, etc. but no luck. Please help! Thanks!
donnena posted Fri, 15 November 2019 at 11:43 AM
Please try checking Window > Editing tools
Andy!
romangirl posted Fri, 15 November 2019 at 1:51 PM
Editing tools has been checked. Doesn't help.
I can't check room tools. Barely visible..
Thanks Andy.
RedPhantom posted Fri, 15 November 2019 at 3:15 PM Online Now! Site Admin
The manual should be opened with a PDF reader like Adobe Acrobat reader rather than notepad. It's possible your editing tools palate was floating and somehow moved off the screen. If you have any UI memory dots saved for the room you're in, you could click on one of those. If not, you'll need to set the interface back to the factory state. EDIT>GENERAL PREFERENCES. Click on the interface tab. Check the launch to factory state option. (make sure you're in the interface tab and not document. the options look similar but won't help) Then reload poser.
romangirl posted Fri, 15 November 2019 at 3:35 PM
Thank you!
