atpo opened this issue on Dec 09, 2019 · 4 posts
atpo posted Mon, 09 December 2019 at 10:35 PM
Thanks.
RHaseltine posted Tue, 10 December 2019 at 3:02 PM
I'm not quite sure what you mean, and the image of the Simulation Settings pane doesn't show whether you had Frames to Simulate set to Current Frame or Animated. If it was Animated, drag the play head to the end and you should see the final drape.
atpo posted Tue, 10 December 2019 at 6:37 PM
Thanks cat.
But not “”Current Frame or Animated“,the second choose.
RHaseltine posted Wed, 11 December 2019 at 9:21 AM
Yes, if you set it to Animated then the final drape would be in the last frame you simulated. Of course the plane does need to have enough divisions to bend - if that is a single division plane then it won't drape nicely whatever you do.
