Subject: Figure Height missing since Poser 11.2 update
Steve_Vaii opened this issue on Dec 17, 2019 · 4 posts
Steve_Vaii posted Tue, 17 December 2019 at 5:53 PM
I didn't noticed it yet, but it seems like the Figure Height function is no longer available since Poser 11.2. There you could have different body sizes, like adolescent, ideal adult or fashion model. Why did Bondware remove this great feature?
WandW posted Tue, 17 December 2019 at 8:34 PM
The Powers That Be decided it was obsolete as most modern figures don't use it, nor the genitalia switch.
There is a script somewhere about that will allow one to access these functions, but I can't seem to lay hands on the download location at the moment...
EDIT: Here t'is
https://www.renderosity.com/mod/freestuff/?download=83353
quietrob posted Tue, 17 December 2019 at 10:40 PM
Just so you know. You're not alone I complained about this months ago. I received some not so good ideas about what to do but in the end I believe the Poser Guru, Structure provided a work around. You should be able to find it at Sharecg as well. Bitdefender just blocked my access to the file for some weird reason. One of the other guru's actually hacked the UI so it would show up there as it was supposed to do.
Steve_Vaii posted Wed, 18 December 2019 at 6:39 AM
You can use the scale function for the whole figure as well, but I think it´s not the same as the figure height. Thanks a lot for the scripts!!!
