jaxon101 opened this issue on Jan 06, 2020 ยท 11 posts
jaxon101 posted Mon, 06 January 2020 at 10:37 AM
First off HELP. I have tried everything I could find on the net. I can not view thumbnails in Poser 11.2.276 on Win10 network drive. Has anybody had this problem and been able to fix it? if so how. Much thanks Jax
hborre posted Mon, 06 January 2020 at 12:45 PM
The latest version I have is 11.2.319 on Win10. There may be one other version over that. Can you show a screencap of your problem?
philadam posted Mon, 06 January 2020 at 5:19 PM
Make sure you are using a drive letter (r:) and not a UNC (like \server\content\Runtime). You can use the command prompt "net use" to verify.
jaxon101 posted Mon, 06 January 2020 at 6:39 PM
hborre just imagine an icon instead of a thumbnail for everything in your runtime philadam I am not familiar with the command but will give it a try but it is g: not unc tuvm Jax
hborre posted Mon, 06 January 2020 at 6:53 PM
Are we talking icon like these:
Hover the icon with your mouse cursor and a path popup will appear in a text field. You can also right-click the icon and have it open explorer to reveal what's in the folder. Check to see if any png thumbnails exist. If you haven't tried yet, click the little refresh icon at the bottom right of your Library and see if that corrects the problem.
jaxon101 posted Tue, 07 January 2020 at 5:25 AM
hborre That's exactly what I get. Before the win 10 upgrade (or downgrade) I had normal thumbnails. The refresh button does nothing. I've never used or setup an external library but may have to give it a try Thanks
kol_2005 posted Sun, 19 January 2020 at 9:16 AM
I have the same problem any ideas on rectifying this ?
jaxon101 posted Mon, 20 January 2020 at 7:02 AM
Hey Kol..I solved my problem. Make sure you have full sharing set up. Map the drive. Turn off show Icons. On the second machine you should see the new mapped drive. Now map that drive and presto all is good. I have never heard of doing it this way but found it on a MS forum for Win10
kol_2005 posted Mon, 20 January 2020 at 7:42 PM
jaxon101 posted at 7:41PM Mon, 20 January 2020 - #4377207
I'll give it a try cheers :)
kol_2005 posted Fri, 24 January 2020 at 6:39 PM
No cannot remap the drives as that would mess up all the pz3 on other system, this really should not be a problem, Daz has no problem with its library, considering how much this program costs this should be a feature available for poser???
kol_2005 posted Sat, 25 January 2020 at 5:41 AM
Anyone from Bond/Renderosity going to answer this question?
