Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Subject: Need Clear Steps To Download Le Femme/Homme
sasacatina opened this issue on Jan 06, 2020 ยท 8 posts
sasacatina posted Mon, 06 January 2020 at 4:04 PM
Hello, I am losing my mind trying to figure out how to properly install both. I know they say the directions are in the file but I can not understand where it is exactly. There are some but... I just need step by step instructions, please. Y~Y My dyslexia could be getting to me for this one.
structure posted Mon, 06 January 2020 at 4:30 PM Forum Coordinator
Copy the runtime from the zip to your poser 11 content folder
Locked Out
LeeMoon posted Mon, 06 January 2020 at 4:32 PM
Hi sasacatina!
I picked up both La Femme Pro and L'Homme Pro recently and used Poser's "Install from ZIP Archive..." menu item to install both products into my designated Runtime folders.
Have you used the Install from ZIP Archive feature before?
Lee
hborre posted Mon, 06 January 2020 at 4:38 PM Online Now!
@ LeeMoon: If you could kindly provide screencap instructions for the OP, I bet he/she would greatly appreciate it. I would do the deed but I am tied up at the moment.
LeeMoon posted Mon, 06 January 2020 at 5:17 PM
Give me a few minutes. I've had a render going.
Will have some basic screenshots of Install From ZIP shortly. 😀
Lee
LeeMoon posted Mon, 06 January 2020 at 5:42 PM
Here you go...
I'm on a Mac, but the same steps should be the same for Windows. Someone please correct me if I'm wrong. 😀
1) Select "Install from ZIP Archive..." from Poser's File menu.
2) Select the La Femme/L'Homme .zip file that you want to install from it's location on your PC/Mac and click "Open".
3) Select the Runtime where you want to install the La Femme/L'Homme files into and then click on "Install".
4) Repeat for each of the product's ZIP files.
I hope this helps!
Lee
sasacatina posted Mon, 06 January 2020 at 7:12 PM
Thank you very much everyone! I had to lay down, but I understand the gist of it now! :D
LeeMoon posted Mon, 06 January 2020 at 8:14 PM
You're very welcome, sasacatina!
I hope you get everything installed just fine.
Lee
