Doc000 opened this issue on Jan 07, 2020 ยท 6 posts
Doc000 posted Tue, 07 January 2020 at 12:48 PM
Everything I load uses the Poser Traditional skinning method, and I manually change things to use Poser Unimesh...which is WAY better.
Is there a way to make things load with the Poser Unimesh set as the default?
Boni posted Tue, 07 January 2020 at 1:57 PM
Could you explain what you mean, and how you convert?
Boni
Boni posted Tue, 07 January 2020 at 2:47 PM
Ignore previous post ... sometimes I just need to refresh my memory and my research. Great idea!
Boni
Doc000 posted Tue, 07 January 2020 at 5:27 PM
Boni posted at 5:23PM Tue, 07 January 2020 - #4375818
Yeah, sorry...I probably should have been more clear...hehe.
I load something and then click the Figure menu, Skinning Method, and change it to Poser Unimesh. I found that it fixes a whole lot of rendering issues, like fixing some AO oddities on some models.
I was just curious if maybe there was a setting in some preference file I could edit to automatically load things with Unimesh sub-division.
Boni posted Wed, 08 January 2020 at 5:48 AM
Hehe ... not that I know of ... but then I've proven that age has caught up with me and my memory isn't what it use to be!! I believe however that I've read that some figure structures don't lend themselves well to Unimesh skinning while others benefit greatly as you have discovered.
Boni
structure posted Wed, 08 January 2020 at 12:43 PM Forum Coordinator
Have you tried saving the edited figure back to the library?
Locked Out
