Forum: New Poser Users Help
Subject: To bring out the background sky?
youngju99 opened this issue on Jan 23, 2020 · 5 posts
youngju99 posted Thu, 23 January 2020 at 12:26 AM
The image below is from a import that Convert the Daz file. By the way, my background is trensparent. I should see the cassini sky like a another sample image.
I want the sky in the background to come out. What should I set up?
i have a hdri map file, but i don't know how to do this, It wasn't a texture file. please help me.ㅠㅜ
i bought this item below: https://www.daz3d.com/downloader/customer/files#prod_51397
donnena posted Thu, 23 January 2020 at 11:32 AM
Try a Control G to hide the Sky dome/background.
Render with Superfly for the HDRI
Andy!
NobbyC posted Fri, 24 January 2020 at 2:12 AM
These background images are HDRI Images. If you like to use them, you need an "environmental sphere". The easiest way is when you use EZ Dome from Snarlygribbly. The Link is: http://poser.snarlygribbly.org One tip when you scale up the inner "sphere" the backround immage "looks" closer and when you scale it down the backround "looks" more fare away.
youngju99 posted Fri, 24 January 2020 at 8:22 AM
thankyou, Donnena and NobbyC! I'll try both of them~
hborre posted Fri, 24 January 2020 at 12:12 PM
Snarly's EZDome can be used for HDRI straight off but may require further processing through the SIBL Edit program. Your best bet is BBs Environmental Dome which will use HDRI directly through the Material Room. This is where you can find it: https://sites.google.com/site/bagginsbill/free-stuff. Snarly's app is based on Bagginsbill's script.
