infinity10 opened this issue on Jan 28, 2020 ยท 40 posts
infinity10 posted Tue, 28 January 2020 at 12:25 AM
I have finished my almost 2-year project to create content for La Femme and more recently, for L'Homme. Content includes low resolution sportswear tops and bottoms and shoes. Software used: Shade3D for modelling, ClipStudioPaintEX and Assets for textile graphics creation, and Poser Pro 11.xxx for fitting and dynamic simulation.
May I please show the results here in this thread. I have the renders and collages at my own Gallery at Deviant Art, and will link them here. I have not yet packaged the wardrobe for distribution at this time.
Eternal Hobbyist
infinity10 posted Tue, 28 January 2020 at 1:59 AM
Starting with the shoe series, I made 5 types of shoes as CR2, and I have named them shoe_a, shoe_b, shoe_c, shoe_d and shoe_e. I made shader materials for each shoe type. All the shaders are for SuperFly rendering only, and use the Cycles Surface root node for the shader tree. (For Poser users who need to devise their own Poser Root Surface shader tree, it's pretty simpl to do.)
This is the shoe_e set at Oh dear, the image from that webpage does not show up. I have no choice but to uploade my image here. Not all styles for shoe_e are shown.
Eternal Hobbyist
infinity10 posted Tue, 28 January 2020 at 2:00 AM
I can't get the images from my deviantArt Gallery to show here, so I am uploading the collages for my La Femme / L'Homme wardrobe directly.
Here are my shoe_d and styles
Eternal Hobbyist
infinity10 posted Tue, 28 January 2020 at 2:01 AM
Here are my shoe_c and styles:
Eternal Hobbyist
infinity10 posted Tue, 28 January 2020 at 2:04 AM
So far, based on my collages, my sheos appear a little bit too loose, perhaps. This is because I intended for them to be used with socks.
Here are my shoe_b and styles:
Eternal Hobbyist
infinity10 posted Tue, 28 January 2020 at 2:06 AM
You can swap around the transparencies I made, and get even more styles - but you will need to do that manually. There are too many combinations for me to created materials MT5 shaders for !!
Anyway, here are my shoe_a and styles, with transparency variations:
Eternal Hobbyist
infinity10 posted Tue, 28 January 2020 at 2:07 AM
And here are my shoe_a and style variations:
and more shoe_a styles:
Eternal Hobbyist
infinity10 posted Tue, 28 January 2020 at 2:11 AM
I have not completed the boots collection, so that will be posted last in this thread.
Meanwhile, here are my clothes, starting with my 3/4 T for La Femme:
and
and
Eternal Hobbyist
infinity10 posted Tue, 28 January 2020 at 2:14 AM
I made a cowl neck shirt for La femme, and here it is and the styles for it as well:-
and
and at night:
Eternal Hobbyist
infinity10 posted Tue, 28 January 2020 at 2:15 AM
I tried to create a cropped bra top and here it is as a layering outer piece, with lace styles:
Eternal Hobbyist
infinity10 posted Tue, 28 January 2020 at 2:18 AM
I created an open-front long-sleeved hoodie for La Femme (I also made on for L'Homme), with style:
and
and
and lastly,
Eternal Hobbyist
infinity10 posted Tue, 28 January 2020 at 2:21 AM
I made a sleeveless turtle which had bad UV so I had to re-work the geometry and UV !
Here is my La Femme Sleeveless Turtle-necked T:
and
Eternal Hobbyist
infinity10 posted Tue, 28 January 2020 at 2:24 AM
I made a Short Rain Coat and it shares the same shaders as the Long-Sleeved Open Hoodie in the preceding post.
Here is one style of my Short Rain Coat using one fo teh shaders from the Open Hoodie set:
Front
Back
The seams don't exactly match up - but I am leaving it !!
Reminder - works for L'Homme set as well.
Eternal Hobbyist
infinity10 posted Tue, 28 January 2020 at 2:26 AM
Taking a break to go make the collages for some new shaders... back in a while
Eternal Hobbyist
infinity10 posted Tue, 28 January 2020 at 2:32 AM
I made a Sleeveless Open Hoodie, and it has its own shader set:
(The back views are out of focus, sorry)
and
and finally
Here is a closer look:
The seams do not match up exactly.
Eternal Hobbyist
infinity10 posted Tue, 28 January 2020 at 2:36 AM
I created a sleeveless T-shirt but I had to tweak the UV many times, until I finally got this set: (I used a draft render quality and denoised using Intel Denoiser)
Sorry for the low quality renders for this set.
Eternal Hobbyist
infinity10 posted Tue, 28 January 2020 at 2:38 AM
I made a Sleeveless Open Vest but I did not make a collage of renders. here are the thumbnails as you would see them in the Poser material library:
Eternal Hobbyist
infinity10 posted Tue, 28 January 2020 at 2:39 AM
I am taking a break now to complete the boots set.
Eternal Hobbyist
Meanwhile, for my shoes, here are some notes:
LF shoes, shader sets for SuperFly rendering only.
shoe a = 13 styles
shoe a with Transparencies = 10 styles
shoe b = 4 styles, more if you manually swap transparencies
shoe c = 6 styles, more if you manually swap transparencies
shoe d = 4 styles
shoe e1 = 5 styles, more if you manually swap transparencies
shoe e2 = 4 styles, more if you manually swap transparencies
shoe e3 = 4 styles, more if you manually swap transparencies
shoe e4 = 4 styles, more if you manually swap transparencies
Eternal Hobbyist
infinity10 posted Tue, 28 January 2020 at 2:51 AM
OK. I have here is what my La Femme Boots look like. Again, just low-resolution geometry. I don't like all the results, and may not release everything, only specific versions.
and
and finally
Eternal Hobbyist
infinity10 posted Tue, 28 January 2020 at 2:54 AM
I created Bermuda-style pants for La Femme, with styles.
Eternal Hobbyist
infinity10 posted Tue, 28 January 2020 at 2:56 AM
I made long leggings with styles for La Femme. (No, I don't think they work for L'Homme)
and
Eternal Hobbyist
infinity10 posted Tue, 28 January 2020 at 2:57 AM
I also made Pedal-Pusher pants for La femme, with styles:
and
Eternal Hobbyist
infinity10 posted Tue, 28 January 2020 at 2:58 AM
I made shorts for La femme, with styles:
Eternal Hobbyist
infinity10 posted Tue, 28 January 2020 at 3:02 AM
Regarding the sleevless t-shirt, which had very low-quality renders, here are the Poser Material Room shaders which give you a better idea of the styles I made.
Eternal Hobbyist
infinity10 posted Tue, 28 January 2020 at 3:07 AM
I did not make renders for my Wing-Collared Shirt for La femme, so here are the thumbnails from the Poser Material library for these items.
This is a low-resolution long-sleeved top with a winged collar. A little bit of UV deformation of the textile graphics here and there, but I am leaving it !
Eternal Hobbyist
infinity10 posted Tue, 28 January 2020 at 3:17 AM
To finish off, the anime-style hair I created for La Femme, using a fitted and grouped skull cap.
and
I don't know if I want to distribute the hair, because it requires a lot of additional in-situ work by the user, before getting the same result as I did.
Eternal Hobbyist
arrow1 posted Tue, 28 January 2020 at 2:33 PM
Looking Great! Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses. Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
infinity10 posted Tue, 28 January 2020 at 6:47 PM
@arrow1 - thank you !
Eternal Hobbyist
infinity10 posted Wed, 29 January 2020 at 2:06 AM
I show the wire mesh view of the various low resolutions items I created for La Femme:
I have not shown the boots because I am still working on the shaders - I may not release the boots so soon.
Eternal Hobbyist
infinity10 posted Thu, 30 January 2020 at 12:50 AM
I hope users (If there are any !) of my leggings will be able to manually use the transparency maps to get the pedal-pusher (or 3/4 length) version, the bermuda (above the knee) version, and the shorts version. I will provide the transparency maps, but not the MT5 files.
Eternal Hobbyist
infinity10 posted Fri, 31 January 2020 at 8:17 AM
I just checked the sandals package. These are the thumbnails you will see in the library for them:
Eternal Hobbyist
infinity10 posted Sat, 01 February 2020 at 3:51 AM
I have more than three ZIP archives to upload, an amount which exceeds the daily allowance for freestuff here.
I'll put my freebies up at sharecg, if that does not cause offense to the site owners here. I am infinity10 over there.
Eternal Hobbyist
JoEtzold posted Sun, 02 February 2020 at 12:47 PM
Just downloaded ... looks totally great. But I missed the boots ... even very less of such footwear compared with the DAZ-ladies ...
arrow1 posted Sun, 02 February 2020 at 12:56 PM
Downloaded as well.Great work! Cheers
infinity10 posted Mon, 03 February 2020 at 4:24 AM
I made a summer dynamic cloth hip wrap - which I also can use as a summer neck scarf - for La Femme, but which can also be re-positioned and re-sized manually for other figures. Basically, users would need to add constrined vertices at the top of the geometry during the set up for cloth simulation. I created the textile textures using Clip Studio Paint EX. There are two versions for each shader, so La Femme can show off the design on either side. This set of shaders will work with Firefly and with Superfly. Here are the thumbnails from the poser shader library for the wrap.
Give me some time to package up this item as an archive. Thank you for your interest.
Eternal Hobbyist
infinity10 posted Mon, 03 February 2020 at 4:32 AM
Give me some time to prepare the archive for the hip wrap / neck scarf set.
Previous post - constrained vertices, typo.
Eternal Hobbyist
infinity10 posted Tue, 04 February 2020 at 8:31 AM
I have uploaded the scarves and hip wrap set.
Eternal Hobbyist
Torquinox posted Tue, 04 February 2020 at 10:59 AM
This looks great! It looks like you put a lot of work in on this.
Richardphotos posted Fri, 14 February 2020 at 12:27 PM
the items for La Femme look great. I have La Femme and Homme. will starting to use her soon. been moving poser zips to a 4 terabyte solid state for weeks now. regular hard drives do not last forever
