Subject: Octopus - Mirror to otherside?
Sadicus opened this issue on Feb 05, 2020 ยท 14 posts
Sadicus posted Wed, 05 February 2020 at 6:02 PM
how to Pose 4 arms then mirror to other-side?
Nails60 posted Wed, 05 February 2020 at 6:33 PM
If you mean the octopus that comes with poser.
Make sure the 4 tentacles you pose are all on the same side (all right or all left)
Then click on figure menu, pose symmetry, left to right or right to left depending on which side you posed
Sadicus posted Wed, 05 February 2020 at 7:00 PM
if only it were that easy. That is what it should do but is not.
an0malaus posted Wed, 05 February 2020 at 8:29 PM
True bi-lateral symmetry requires sign changes on X translations and Y & Z rotations (in the simplest form that relates to human figures, at least). Poser knows how to do that, but cannot do so for morphs unless they contain a paired L/R suffix, so it can't tell that SideSideAll is a master channel for z-rotations. If you were to bake those morphforms (a common name for master channels) out to the individual limb actor rotations, then Poser's symmetry functions could work with them. Unfortunately, there is no (simple) way to uncook an egg or replace a set of common limb rotations back into a morphform that controls them.
Looking through the free stuff and marketplace came up with this: NetherWorks' PoseWriter Panel as the only readily available option for morph symmetry. I have written such scripts for my highly customised V4 figure, without the UI, though, and there is a great deal of customisation required to identify trunk and limb control morphforms (master parameters) which are subject to symmetry transfers. The Giant Octopus is certainly a prime candidate for such treatment, but my script would take significant work to bring up to the same standard and general figure applicability as NetherWorks' offering, so I'll leave it at that.
My ShareCG Stuff
EClark1894 posted Wed, 05 February 2020 at 8:38 PM
It looks like you're morphing it, not posing it.
an0malaus posted Wed, 05 February 2020 at 8:59 PM
No, @EClark1894, the SideSideAll channel on the root of each tentacle is an EZPose type control that drives the zrot channel on each actor of that tentacle. Ultimately, no morphs are involved, but the channels are likely to be targetGeoms, rather than valueParms. The problem is simply that it's no easy matter to identify that they are subject to symmetry without detailed analysis of the valueOperations. That said, it could be done, and Poser should do it natively. I have made this request for subsequent releases, as it's not impossible to do, just a bit involved.
My ShareCG Stuff
EClark1894 posted Wed, 05 February 2020 at 9:05 PM
Are you sure? He looks like he's got a value on the second morph dial in that shot and it's highlighted indicating it's been selected. The SideSide dial is reading 0.
an0malaus posted Thu, 06 February 2020 at 1:42 AM
It's not a morph. It's a master parameter. I've loaded the figure and there are no deltas. Its valueOperation dependencies form a chain down all the child actors affecting their zrot parameters, which causes the curl of the tentacle. This is not a morph effect. It's purely rotations controlled by a single dial.
My ShareCG Stuff
Glitterati3D posted Thu, 06 February 2020 at 10:16 AM
click on the morph dial arrow to the right, and select Match Centers to Morph.
Once done, zero your figure and re-save and it will be saved with that parameter.
DCArt posted Thu, 06 February 2020 at 1:28 PM
an0malaus posted at 2:27PM Thu, 06 February 2020 - #4379256
Does figure > rig symmetry > left to right fix it?
an0malaus posted Fri, 07 February 2020 at 1:46 AM
Why would that fix it? The rig is almost certainly already symmetrical. You don't reverse the sense of +ve rotations on opposite sides of the body for symmetry, you change the sign of the value. It's not a rigging problem. It's a master channel on each tentacle that applies in a consistent rotational sense, +ve gives a positive z rotation on all child actors, which is what is seen in the posted image. There is nothing to tell Poser that a master channel on an actor on one side needs a sign change to give a symmetric appearance when applied to a master channel on the opposite side, especially if the channel on all actors is called SideSideAll. How is Poser supposed to know just from the name that, like zrot and yrot channels, left/right symmetry requires a sign change on the opposite side of the body. Unless Poser analyses master channels to see whether they ultimately control actor rotation channels with signed symmetry, it cannot apply symmetry to such channels.
My ShareCG Stuff
DCArt posted Fri, 07 February 2020 at 1:58 AM
I figured it might be worth a shot, not knowing how EZPose applied the rotations to all the tentacles.
an0malaus posted Fri, 07 February 2020 at 2:09 AM
A simpler fix might be to create additional master channels on the BODY or head actors that drive symmetrical settings of the master channels on each pair of tentacles, that way one dial will give a symmetrical pose of a pair of tentacles. If Poser's symmetry functions won't do the job, use valueOperations instead.
Say in valueOp syntax:
actor rTentA01:1
channels
    targetGeom SideSideAll
        valueOpDeltaAdd
            Figure 1
            head:1
            TentASideSideAll
        strength -1.000000
        deltaAddDelta -1.000000
actor lTentA01:1
channels
        valueOpDeltaAdd
            Figure 1
            head:1
            TentASideSideAll
        strength 1.000000
        deltaAddDelta 1.000000
My ShareCG Stuff
an0malaus posted Fri, 07 February 2020 at 2:19 AM
I did actually try what you suggested, but it didn't make any difference. Pose symmetry does work for pure rotations on the tentacle actors, but unfortunately, it copies the morph values directly, so lTentA01:SideSideAll = 2.0 gets copied to rTentA01:SideSideAll also = 2.0, but those master channels are additive valueOps on the tentacle zrotations, so both tentacles curl to the left (+ve zrot), whereas, since they need to be symmetrical, there should be a sign change as there is with just the pure zrotations.
With left to right symmetry applied on only rotations, the correct result ensues: Screen Shot 2020-02-07 at 7.15.30 pm.png
With a master control set on the left, symmetry just copies the save value to the right side, giving non-symmetric results:
To get the symmetric result, a sign change is required. Poser could do this, with a bit of intelligent exploration, but doesn't ATM:
My ShareCG Stuff
