davo opened this issue on Feb 07, 2020 ยท 3 posts
davo posted Fri, 07 February 2020 at 11:10 AM
I have an Nvidia GTX 745. When I run poser pro 11.2 (and this happened on prior releases, too) with OpenGL rather that scree, strange things will happen when I do things like delete an item. The item will not disappear from the preview window, it still shows, and the scene freezes up, if I switch over to the render tab, then back, the item will be gone from the preview window. Same things happens sometimes when I apply a pose, the preview window freezes up, switch over to the render tab, back again to preview, the change has taken place.
Has anybody encountered this problem or know of a fix?
Cheers,
Davo
Necromuncher posted Fri, 13 March 2020 at 1:10 PM
Thanks to Davo, I was able to "fix" or rather find a workaround for a problem i've encountered. Sometimes, deleting specific items in a scene would just crash Poser everytime. Switching from OpenGL to SreeD allowed me to delete the items in question and then continue working with OpenGL again. It still is kinda strange and also quite annoying if you have the chance of Poser crashing simply by removing an object or figure from the scene by pressing "delete".
A fix for that would be neat.
HartyBart posted Fri, 13 March 2020 at 7:58 PM
You might want to update your install of OpenGL to the latest version. Last time I looked it was 4.5.
