RedPhantom opened this issue on Feb 10, 2020 ยท 12 posts
RedPhantom posted Mon, 10 February 2020 at 5:21 PM Online Now! Site Admin
In ver 2.80 there are menus at the top of the 3d viewport that when I load a scene made in 2.79 drop to the bottom.
Is there any way to stop that?
Miss B posted Mon, 10 February 2020 at 6:06 PM
I can remember opening very old .blend files from the 2.4x versions in 2.5x when I finally got the newer version, and it did the same thing.
The only thing I think you can do, and I'm not sure where it is in version 2.8, but when I try to open a .blend file, near the bottom of the left Tool panel, there's an option to Load UI, and it's checked by default, so IIRC, you can uncheck it before loading up the file in 2.8, and then it will display as you want in 2.8's UI.
_______________
keppel posted Mon, 10 February 2020 at 6:56 PM
In 2.8 the Load UI check box is located at the top right corner of your "Open File" screen under the setting or cog shaped button.
My Renderosity Store
Virtual Furnishing
My Portfolio
RedPhantom posted Mon, 10 February 2020 at 7:14 PM Online Now! Site Admin
Thanks. That works. Consistency makes it so much easier.
Miss B posted Mon, 10 February 2020 at 7:33 PM
Thanks for confirming it's still available in 2.8x, and where it is. I'm going to have to make a note for when I can start playing with it.
_______________
Lobo3433 posted Mon, 10 February 2020 at 7:52 PM Forum Moderator
Thanks learned something myself it never occurred to me to look that up I usually just append a new scene with the objects from an old scene which is actually time consuming if it is a large scene thanks Miss B and keppel for this info
Lobo3433
Blender Maya & 3D Forum Moderator
Renderosity Blender 3D Facebook Page
Miss B posted Mon, 10 February 2020 at 10:33 PM
RedPhantom posted at 11:32PM Mon, 10 February 2020 - #4379875
Hmmmm, now I'm wondering if I do that and save it as my Startup scene, whether it would remember to not have that checked. Hmmmm . . .
_______________
RedPhantom posted Tue, 11 February 2020 at 6:42 AM Online Now! Site Admin
I was wondering the same thing.
Miss B posted Tue, 11 February 2020 at 8:20 PM
Well, I just tried, and it doesn't work. I'm now going to try and see if there's a User Preference that can set that to be unchecked all the time.
_______________
Miss B posted Tue, 11 February 2020 at 8:36 PM
YES!!! I just found it!!! Open the User Preferences, and click on the File tab. It's in the list on the right, and it works. I unchecked it, saved my preferences, resaved my Startup.blend file, and when I opened a "New" file, IT'S UNCHECKED!!!
Just remember, the User Preferences might look different in 2.8x, but it should still have the same list of options.
_______________
LuxXeon posted Thu, 13 February 2020 at 8:48 PM
@MissB Yes, it's the same in the 2.8x preferences as well. Just uncheck the option and you won't have to worry about it going forward. Keep in mind that some .blend files are intentionally shared with a custom UI in place so that instructions or warnings about how the file was made can be displayed upfront, but as long as that isn't a concern, it's better to keep that option turned off.
______________________________________
My Free Models
My Video Tutorials
My CG Animations
Instagram: @luxxeon3d
Facebook: https://www.facebook.com/luxxeon
Miss B posted Thu, 13 February 2020 at 11:03 PM
LuxXeon posted at 11:59PM Thu, 13 February 2020 - #4380347
Thanks for confirming that Lux. I wish I had known about that option years ago, if it existed back in Blender 2.5x, because every time I opened one of my old 2.4x .blend files, I had to close and reopen it, unchecking that option. This way it's done automatically, which is always easier.
_______________
