RAMWorks opened this issue on Feb 25, 2020 ยท 10 posts
RAMWorks posted Tue, 25 February 2020 at 11:18 AM
Hi,
Created a heavily modified "cat suit" for L'Homme to make clothing for him with. Loaded in the Dev Suit for La'Femme, transferred the morphs from L'Homme to it and of course I couldn't figure out how to get the height to transfer so took that into ZBrush, grew it and fixed poke throughs and and re-meshed it allot to get a much lower poly count and set up the poly-groups to my liking. Exported it and well it comes in about half in the floor when imported back into Poser. I'd like to know how to import it so it comes in where it should.
Thank you, Richard
---Wolff On The Prowl---
RedPhantom posted Tue, 25 February 2020 at 11:28 AM Online Now! Site Admin
In the import dialog that pops up, there is an offset option. Adjust the y offset. You may have to expirament. Or if the suit is supposed to touch the ground, you can use the place on floor option.
infinity10 posted Tue, 25 February 2020 at 11:38 AM
Need to check "place on floor" option when importing the OBJ ito Poser.
Eternal Hobbyist
RAMWorks posted Tue, 25 February 2020 at 12:00 PM
Seems a bit fidgety to me. After about 30 tries with various yTran and zTran settings in the importer I sort of got it. MUST be a simpler way than that! WOW!
RAMWorks posted Tue, 25 February 2020 at 12:17 PM
Seems that the GoZ export to Poser seems to work the best. I'll have to remember that!
RAMWorks posted Tue, 25 February 2020 at 3:02 PM
SO another question. Probably stupid one but here goes...
Is there a way to "auto rig" clothing in Poser like one can do in DAZ Studio? I went into the set up room and well... that was all she wrote. I had NO IDEA what to do in there. I didn't see any controls or a way to perhaps copy and transfer the L'Homme rigging to the Catsuit so feeling a bit lost here
Thanks for any help, links or advice!
Richard
FVerbaas posted Tue, 25 February 2020 at 4:12 PM Forum Coordinator
Well there is a manual and most likely some tuts. Essentially you select the clothing object and the target figure and ask the fitting room to combine them into a figure. You can use the fitting tools and the grouping tool but that is just an option.
RAMWorks posted Tue, 25 February 2020 at 4:30 PM
Thank you. Yea, I had the wrong room. Fitting, not Setup! I found a YouTube vid for that, it's 4 years old but I think it all still applies to the Poser 11 Pro....
RedPhantom posted Tue, 25 February 2020 at 7:51 PM Online Now! Site Admin
No, the fitting room hasn't changed much, if at all. If you need help, ask.
RAMWorks posted Wed, 26 February 2020 at 10:32 AM
