Dowjonsie opened this issue on Feb 28, 2020 ยท 15 posts
Dowjonsie posted Fri, 28 February 2020 at 10:49 PM
Hello, I have been trying to get bulletphysics/softbodies in a poser scene for a while now. I thought the original problem was a model having 140k polies, until i loaded a scene with the model and NO bullet painting. Preview slows to a crawl with live simulations enabled, ticking what would be a frame every 10 seconds even without any weight painting on any model.
I have an i7 a d a 1060gtx so I am findi g it hard to believe my hardware is at issue, and not an internal parameter (i hope). I have seen tutorials with people using less powerful hardware. Any help woumd be extremely appreciated.
ghostship2 posted Fri, 28 February 2020 at 11:08 PM
That is a big assed model to begin with and I would expect any computer would slow to a crawl with it loaded. why not start out experimenting with smaller models and work your way up to higher poly count?
ghostship2 posted Fri, 28 February 2020 at 11:10 PM
V4 is only 66k polys and that is considered a dense mesh
Dowjonsie posted Fri, 28 February 2020 at 11:53 PM
Preview is totally fone when not using live simulation. I should also add that i have tried bullet on v4 and same thing happened, its just slightly faster. But, its happening even when no ohysics paint are applied. I have no idea what my issie is. My laptop is fairly beefy. Are there parameters or preferances i can adjust? Maybe bp os attenoting to use integrated graphics instead of my gtx? How can i check things like that?
ghostship2 posted at 11:51PM Fri, 28 February 2020 - #4382090
adp001 posted Sat, 29 February 2020 at 4:59 AM
Physics engines aren't made to deal with high-res meshes (not only in Poser). Use a low-res proxie to manage objects with high poly-count.
Background: Even without anything special defined the physics-engine has to compute real hard maths for every single vertex (4 per polygon).
an0malaus posted Sat, 29 February 2020 at 6:02 AM
Another question to ask will be (given some measure of doubt about multi-threaded bending improving performance) is the physics simulation code written to take advantage of multiple CPU cores/threads simultaneously? Do we have confirmation of that?
EClark1894 posted Sat, 29 February 2020 at 10:05 AM
What exactly are you trying to do? I'm trying to learn how to use Bullet Physics more effectively, and I haven't had any slowing to speak of. The one issue I do currently have has nothing to do with the number of polys.
Dowjonsie posted Thu, 05 March 2020 at 5:35 PM
Trying to make softbody physics. Particularly, breast, butt and thigh jiggle.
EClark1894 posted at 5:35PM Thu, 05 March 2020 - #4382127
Dowjonsie posted Thu, 05 March 2020 at 5:36 PM
There is apparently a coding script to have bp utilize openGL for graphics computation. But i dont think poser makes use of this in any way.
an0malaus posted at 5:36PM Thu, 05 March 2020 - #4382111
Dowjonsie posted Thu, 05 March 2020 at 5:41 PM
How do you mean? I am using Aiko 4 for v4. She apparently buffs the usual poly count to 133k. Just peeped that lmfao. Could i not just reduce her poly count to 40k ? What do you mean by a proxy?
adp001 posted at 5:39PM Thu, 05 March 2020 - #4382108
Dowjonsie posted Thu, 05 March 2020 at 6:00 PM
I tried simply reducing the models poly count to 40k and that barely did any justice. As a matter of fact, it made things harder to work with, destroying all my grouped morph hierarchies. I would love if you could either provide a tutorial or some instructions to your wwy going about this.
adp001 posted at 5:59PM Thu, 05 March 2020 - #4382108
adp001 posted Thu, 05 March 2020 at 7:47 PM
Start with not using all actors. Set only those actors to dynamic you need to "jiggle" (chest, thigh). Most polys are in head, fingers and feets. And set Sub-D to 0 while working on your figure.
EClark1894 posted Thu, 05 March 2020 at 7:54 PM
For the record, I have used V4 in Bullet and had no problems. I was just writing a new blog for my website on Bullet Physics in Poser. One of the chief changes I advocate for is a list of Poser Presets or at the very least tutorials that show you how to set up for a jiggly body or bodyparts.
EClark1894 posted Thu, 05 March 2020 at 8:11 PM
Here is a thread I found at the old SM forum that MAY help. It doesn't explicitly lay out step by step what you need to do, but I thought it might help you figure it out.
https://forum.smithmicro.com/topic/2101/all-of-the-best-features-of-poser-in-one-animation-nsfw
Dowjonsie posted Fri, 06 March 2020 at 4:03 AM
This is useful. Im learning grouping and control props now so i think some knowledge there will go far come time for incorporating physics.
EClark1894 posted at 4:02AM Fri, 06 March 2020 - #4382690
