Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Subject: why is my poser files, obj, etc having different extentions now.
Jin_Yindao opened this issue on Mar 20, 2020 ยท 4 posts
Jin_Yindao posted Fri, 20 March 2020 at 12:30 AM
Have been working hard to retrieve contents of scenes. Now am finding a lot of files that I need now have the extention .ABC or .tmp, or .pov. am on a windows system and these were all working folders until main drive failure. They were all retrieved from one of the failed drives but now have the wrong ext. so what do I do?
Dive into Fantasy and Ride the Waves
I have many scenes in my head, but non of those are on paper.
I have yet to learn to bring those to life.
The ones that I give life, are not those I see
Kerya posted Fri, 20 March 2020 at 2:21 AM
Do you know what extension they should have? Try renaming them and test whether they open in the expected way?
ironsoul posted Fri, 20 March 2020 at 3:06 AM
They maybe temporary files created by a program, for example if the source file was an obz, the program may have uncompressed the contents into a temporary file before processing. Another possibility is the recovery process found the body of a file without the name so created a temporary name. In addition to following Kerya's post if the file is not too large you could try loading it into notepad to see if the contents are readable (eg obj) or they contain a readable signature at the beginning of the file.
EnglishBob posted Fri, 20 March 2020 at 7:12 AM
.ABC and .TMP files are created by the Poser cloth simulator when it runs. You can safely leave them as they are.
