Forum: Blender
Subject: blender into poser
bluto opened this issue on Mar 22, 2020 · 6 posts
bluto posted Sun, 22 March 2020 at 4:22 PM
i am dumbfounded . i had a friend build a model for me to use in poser . he built it in blender converted it into obj format and i get something like this when i load it into poser!
can anyone advise me or better yet fix it
LuxXeon posted Sun, 22 March 2020 at 4:39 PM
Looks like he used Ngons for the flat surfaces and the normals and triangulation got messed up. Are the holes in the sides supposed to look like that? This just seems like a problem with the triangulation and normals after exporting. If you can upload the OBJ, I could have a look at the topology in Blender and see if I can fix it for you. Otherwise, he may need to remodel this and avoid using Ngons and make sure the normals are all facing the right way before exporting.
______________________________________
My Free Models
My Video Tutorials
My CG Animations
Instagram: @luxxeon3d
Facebook: https://www.facebook.com/luxxeon
RobynsVeil posted Sun, 22 March 2020 at 4:40 PM
Not sure what your model is meant to look like (a render in Blender might help) but in any case, in Blender, you might wish to confirm that all faces are pointing the same way. Also, keep in mind that typically, objects exported from Blender into Poser will need to be resized to 1/10th, as Poser's native size is ridiculously small.
[it is clear that humans have contempt for that which they do not understand]
Metaphor of Chooks
Lobo3433 posted Sun, 22 March 2020 at 4:46 PM Forum Moderator
I am almost 100% sure the top of that cylindrical shape is a Ngon it either needs to be converted into tris or quads Poser does not handle ngons well at all a render of the model of in Blender would be helpful like suggest by RobynsVeil
Lobo3433
Blender Maya & 3D Forum Moderator
Renderosity Store
My Free Stuff
Facebook
Twitter
Renderosity Blender 3D Facebook Page
bluto posted Sun, 22 March 2020 at 8:54 PM
LuxXeon posted at 8:47PM Sun, 22 March 2020 - #4384242
thanks i will need to know where to send the file though
RubiconDigital posted Sun, 12 April 2020 at 10:54 PM
I'm a bit late late to the party on this one, but yes, definitely looks like ngons, which Poser and Daz Studio refuse to render properly. Any object intended for use in Poser or DS absolutely must be made up of quads and/or triangles. Also, Blender's .obj export function is basically borked. I had serious issues recently with getting a Blender mesh to render correctly in DS. It was all triangles too. I imported the Blender exported object into Wings and exported it straight out again. It then worked fine in DS.
