Notsrella opened this issue on Mar 30, 2020 ยท 5 posts
Notsrella posted Mon, 30 March 2020 at 4:06 PM
Hello, 11.3 seems to be working fine. However when the program is closed I get 'Poser Pro executable file has stopped working..check on line for a solution...close the program' Which has, of course, already happened! Looking at the 'Problem details' ...'Fault module name python27.dll' and 'Fault module version 2.7.17150.1013' and 'Fault module time stamp 5e815992'
As I say the program seems to work ok but this closing message could get irritating.
hborre posted Mon, 30 March 2020 at 4:31 PM Online Now!
Did you reboot your system as instructed by install? If you did, I would repeat that step again. Otherwise, it sounds like you may need to go through the whole installation process again to see if it corrects itself.
Notsrella posted Tue, 31 March 2020 at 4:02 AM
Hello hborre, Thanks for replying. I did as you suggested but I'm afraid it still comes up with the message on closure. As I say the actual program runs fine so I'm not going to get hysterical about it. As I said in the 'problem details' the python27.dll file is mentioned. Could this be a factor?
hborre posted Tue, 31 March 2020 at 11:29 AM Online Now!
It could be a factor. I have python errors whenever I resave a scene. It all began with some sort of incompatibility between Snarly's scripts in Poser Pro 2014 and Poser 11 Pro. It's an annoyance but as long as it doesn't disrupt my workflow or corrupt files, I'll manage.
Notsrella posted Tue, 31 March 2020 at 2:41 PM
Thanks again, hborre, I've a dislike of .dll's . My first (low spec.) computer, had Win 95. Every time I switched on some .dll. would be missing and the d----d thing wouldn't run! That was long ago. A world without imperfection seems to be unattainable! Keep safe!
