Habatchii opened this issue on Apr 11, 2020 ยท 6 posts
Habatchii posted Sat, 11 April 2020 at 8:40 AM
Quick question.
Cycles is the premiere render engine for Blender, from which stand alone versions may be used with other programs.
The Question: How do you configure Cycles in Poser Pro?
infinity10 posted Sat, 11 April 2020 at 8:47 AM
Go to Materials Room. Right click within the Materials window. Select New Node. Select Root. Select Cycles Surface. The additional Cycles nodes are at the bottom of that pop up. Note: Blender Cycles nodes connect left to right; Poser Cycles nodes connect right to left.
Eternal Hobbyist
RedPhantom posted Sat, 11 April 2020 at 10:56 AM Site Admin
Also, use your render settings to choose superfly as your render engine.
hborre posted Sat, 11 April 2020 at 10:57 AM
Also, not all Cycles features are included in the Poser 11, so translating nodes from Blender to Poser may not yield the same results. BTW, if you are actually using Poser 11, refrain from referring it to Poser Pro, Poser Pro is an actual, earlier version and may confuse other individuals when you are seeking help.
EClark1894 posted Fri, 17 April 2020 at 12:01 PM
Also note, Cycles nodes applied in Blender will NOT be imported into Poser. You WILL have to apply the nodes again.
hborre posted Fri, 17 April 2020 at 12:19 PM
A tedious process even if you know what you're doing.
