MikeMoss opened this issue on Apr 26, 2020 ยท 6 posts
MikeMoss posted Sun, 26 April 2020 at 9:58 AM
Hi, this isn't a new problem but I finally decided to see if anyone knew what the problem is? I was messing around trying to do a texture that had very little color in it, almost black and white. I ran into a problem I've had often before.
Though the eyebrows on my character are black they always appear a rather light brown on the figure. You can see in the comparison that the color isn't the same, the 3 lights are all white, and they black and grayish areas around the eyes look normal but the brows just above that are light brown. You can see that everything is more on the brownish hue then the original but the brows come out much lighter as well.
If you shoot a mime, do you need a silencer?
MikeMoss posted Sun, 26 April 2020 at 10:10 AM
Well it won't let me add anything, so I want to say that I moved the lights around etc. and nothing I did have any effect on the way the brows look.
hborre posted Sun, 26 April 2020 at 10:21 AM Online Now!
You neglected to say which model you are using. What do the Material Room nodes look like for the head? And is there a separate eyebrow zone for the model that you are overlooking?
MikeMoss posted Sun, 26 April 2020 at 11:57 AM
The model is Jessie and the setting are more of less out of the box, I've had this before so why are the colors on the eyebrows affected and not the rest of the image. I've never been able to figure it out but when it happens nothing will change the way it looks, I just thought this example that shows other dark gray to black colors right next to the one that changed show how weird it is. I just thought, I wonder what happens if I change the eyebrows to red or something, will they still be different from the artwork. I'm betting not, I only run into this with black, things that are supposed to be black come out medium brown instead.
hborre posted Sun, 26 April 2020 at 1:33 PM Online Now!
Looking closely at your image it appears that you have 2 sets of eyebrows on her face, the black from your custom and the light brown just above it from a previous texture map I assume. I'm afraid you'll need to empty your texture cache. Other users have complained about textures not reloading when changed in the scene.
Boni posted Mon, 27 April 2020 at 6:37 AM
Are you using the upper brows or strictly the brows from the diffuse map?
Boni
