Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Subject: Subdivide distort
Karth opened this issue on May 02, 2020 ยท 8 posts
Karth posted Sat, 02 May 2020 at 3:30 PM
my uv map in Poser 11.2 and Poser 11.3 I have never had problems with that. But last thing i did in Poser 11 is a while ago. I test a few clothes for LHomme ( basic tshirt ) that i bought and they do the same...reason why no one seems to build a subd mesh ? I checked a few subdivide options in another software. Catmull Clark - edge would fix that in that software. Any idea ? greetings Karth
caisson posted Sat, 02 May 2020 at 7:55 PM
I make subD meshes, but I use UV Layout Pro to create UV's - it has a subD option. Poser uses Pixar's OpenSubDiv which is Catmull-Clark subD AFAIK. Can you post some screenshots that show the problem you're getting?
Not approved by Scarfolk Council. For more information please reread. Or visit my local shop.
Karth posted Sun, 03 May 2020 at 3:16 AM
Sure :-)
Karth posted Sun, 03 May 2020 at 5:39 AM
First i notice that after i setup the cloth for LHomme. Was wondering. never noticed such a problem before with Poser subd. I load an older cloth for La Femme today..a suit by Rpub. And when i subd that i notice the same problems now. Maybe there was a change from Poser 11 to Poser 11.2 ? This makes the subd option unusuable
Karth posted Sun, 03 May 2020 at 8:19 AM
oki..i installed Poser Pro 2014...has subd too..and all is fine !!! subdin poser 2014.jpg
caisson posted Sun, 03 May 2020 at 10:50 AM
There was a change in the boundary rule between PP2014 and P11 to make subD work better with older meshes - in PP2014 everything was smoothed, in P11 the corners remain sharp (i.e. a vertex with two edges will not smooth). I don't have PP2014 anymore though, so can't test that.
I've duplicated this issue with some other LF clothing and will put in a bug report. @Karth - it would help if you would do the same via the form at support.posersoftware.com as the more they get on this the higher the priority it will receive.
I will say that from a content creation POV subD is usable as I've been making subD meshes for years for Poser. However, as my meshes are designed for subD I always UV map the subD mesh, not the poly cage, so I've not come across this issue.
Screenshot below is of La Femme's Fad sneakers with a procedural checker material and textured wireframe display mode. The distortion is quite clear when the subD level is changed.
caisson posted Sun, 03 May 2020 at 11:14 AM
I think that OpenSubDiv was updated from v2 in PP2014 to v3 in P11, so might also be relevant. I'll add it to the report.
Karth posted Sun, 03 May 2020 at 11:46 PM
Many thanks for the explanation Caisson :-) I send a email to Jenn yesterday. So that she can send the information further. Hope they will fix that soon.
