atpo opened this issue on Jun 22, 2020 ยท 15 posts
atpo posted Mon, 22 June 2020 at 12:26 AM
I do a cloth and custom morph, but I cannot move morph from parameter to shaping tab. Thanks.
RHaseltine posted Mon, 22 June 2020 at 3:25 PM
The morph should be in the Actor group and should have its type set to Modifier/Shape. You can do that through the Parameter Settings dialogue, which is launched by clicking the gear icon on the slider.
atpo posted Mon, 22 June 2020 at 6:21 PM
Thanks cat.
atpo posted Mon, 22 June 2020 at 8:47 PM
But
Thanks.
RHaseltine posted Tue, 23 June 2020 at 3:28 PM
The Path needs to start with Actor, not Morphs, as far as I know.
atpo posted Tue, 23 June 2020 at 6:26 PM
Thanks cat,
atpo posted Wed, 24 June 2020 at 12:30 AM
And I check that no" actor" in path.
Does "shaping" tab is for DAZ people only? So any morph for genesis can be moved from parameter to shaping tab?
Thanks.
RHaseltine posted Wed, 24 June 2020 at 3:40 PM
As far as I know the shaping Pane should work with any figure. You did make sure the path shown in the Parameters Settings dialogue started Actor (it is Morphs/Morph Loader in your screen shot)?
atpo posted Wed, 24 June 2020 at 6:32 PM
Thanks cat. "make sure the path shown in the Parameters Settings dialogue started Actor ", which I cannot understand it. How to operate it ?
RHaseltine posted Thu, 25 June 2020 at 4:38 PM
In you last image you have put a circle around the Type box. Just above that is the path box, showing
Morphs/Morph Loader
change that to
Actor/Back/Real World
or whatever seems the best place for your morph.
atpo posted Thu, 25 June 2020 at 6:35 PM
Thanks cat. And I check that no 'Actor/Back/Real World' in path.
But a cloth save as /support/figure/prop, then choose "Actor' but not "wardrobe", which does path show 'Actor'? I save as
"wardrobe",.
And a question is that a cloth which applied "transfer utility" can save as 'Actor',?
atpo posted Thu, 25 June 2020 at 7:57 PM
Thanks cat. Maybe I know what to do.
RHaseltine posted Fri, 26 June 2020 at 2:46 PM
No, I am saying in the Parameter Settings dialogue change the Path from Morphs/Morph Loader to Actor/Back/Real World - the path, which is how the morphs are grouped in the Parameters pane, should start with Actor if you want the morph to appear in the Shaping pane.
atpo posted Fri, 26 June 2020 at 6:54 PM
Thanks cat.
EldritchCellar posted Sun, 28 June 2020 at 10:48 AM
And he was forever thereafter known as Cat. True story
W10 Pro, HP Envy X360 Laptop, Intel Core i7-10510U, NVIDIA GeForce MX250, Intel UHD, 16 GB DDR4-2400 SDRAM, 1 TB PCIe NVMe M.2 SSD
Mudbox 2022, Adobe PS CC, Poser Pro 11.3, Blender 2.9, Wings3D 2.2.5
My Freestuff and Gallery at ShareCG
