anniemation opened this issue on Jul 07, 2020 ยท 3 posts
anniemation posted Tue, 07 July 2020 at 10:06 AM
This is something new. I was noticing that Poser would crash when trying to open previously saved files. So I opened them up in a text editor and found over 150k lines garbage code for a couple of different props.
Once I remove the code the file opens.
nerd posted Tue, 07 July 2020 at 1:48 PM Forum Moderator
the "f" lines are facet data. Same as the f lines in an OBJ file. Removing them would make the object not render visible. It may be there was invalid geometry.
If you still have the file please submit a ticket to support and attach the file causing crashes.
anniemation posted Tue, 07 July 2020 at 2:02 PM
The corrupted file?
