Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Subject: About the Anime characters for La Femme and L Homme
infinity10 opened this issue on Aug 09, 2020 ยท 2 posts
infinity10 posted Sun, 09 August 2020 at 9:12 AM
I note that the Eyelash Mat Poses are intended for a so-called "Layer 2" of the eyelashes, in the Material Room. You will need to manually create a Layer above the Base layer, which the Mat Pose is unable to create. The work-around is as follows: Apply the Eyelash Mat Pose you desire (there are 3 to choose from). Now in the Material Room, go to the Eyelash material. Add a Layer by clicking on the plus (+) sign next to the word Base. Copy the shader nodes in the Base lay over to the layer called Layer_1. Apply the Full Mat and/or the Head Mat after this step.
If you don't do these steps in this order, there will be an artifact appearing in the eyeball when the eyes are moved.
Eternal Hobbyist
infinity10 posted Sun, 09 August 2020 at 9:50 AM
UPDATE: APPLY THE EYELASH MAT POSE FIRST, then create the layer above the Base. Transfer the nodes from Base to the upper layer. The apply the full mat pose and/or the head mat pose.
The eyelash mat pose keeps deleting the added layer.
Eternal Hobbyist
