Cosmasad1 opened this issue on Aug 14, 2020 ยท 2 posts
Cosmasad1 posted Fri, 14 August 2020 at 3:21 PM
Hello,
If I want to buy clothes, hair etc on the Renderosity website, I go to Marketplace/ Departments/ 3d Figure Assets and then use the filters on the right side of the page. For Software, if the version of Poser I am using is 11.2 should I just choose 11 or should I choose all of them including 11?
Thank you.
jennblake posted Sat, 15 August 2020 at 8:17 AM
Hi.
It really depends on what figures you are using in Poser. If you use La Femme and L'Homme then clicking only the P11 software would be fine.It also depends on the render engine you use. P11 has the Superfly engine and those take a bit different materials to render correctly. So that also would be under the P11 software option. But if you use FireFly or you use other characters then I would suggest clicking the others. But I I would click P11..browse those items, then another version..and so on. If one selection does not have all the items in another .. you will never see them.
to see the latest new items for Poser, just go to marketplace/New Poser products.
If you have a particular figure you use, you can also do a search by that figure name to get more exact results for what you are looking for.
Hope this helps!
Jenn
