saibabameuk opened this issue on Aug 27, 2020 ยท 13 posts
saibabameuk posted Thu, 27 August 2020 at 11:58 PM
Were can I find my Face Room strange layout has presented itself. Any ideas
Boni posted Fri, 28 August 2020 at 7:11 AM
Have you been moving elements in your workspace? It looks like you have docked your faceroom modules along with the joint editor in your faceroom tab. First move would be to go to Menu>Edit>General Preferences>Launch behavior ... pick "launch to factory scene' then restart Poser. If that doesn't fix this, come back and we'll see what the next step is.
Boni
saibabameuk posted Fri, 28 August 2020 at 8:57 AM
Boni Lass they say in Scotland lets hope it is ! Thanks Be Back *
saibabameuk posted Fri, 28 August 2020 at 9:06 AM
Followed the instructions and cleared the cash just in case but still a problem.
saibabameuk posted Fri, 28 August 2020 at 9:07 AM
Followed the instructions and cleared the cash just in case but still a problem.!
saibabameuk posted Fri, 28 August 2020 at 9:35 AM
Boni
We did it, the problems for the moment are over. Window/ Room Tool / Face / Face Preview.
I was under the impression that Poser 11 had left out face room, as they have done with Render/ Shadows on Super Fly Render, a real nuisance for Animators.
saibabameuk posted Fri, 28 August 2020 at 9:36 AM
Face Room
saibabameuk posted Fri, 28 August 2020 at 9:37 AM
Is this the completed Page Layout.
Boni posted Fri, 28 August 2020 at 5:25 PM
You got it!
Boni
saibabameuk posted Fri, 28 August 2020 at 10:24 PM
Boni So this is my cloth room factory setting?
Boni posted Sat, 29 August 2020 at 8:12 AM
This happens once in a while . .. just happened to me this week as well. If you click on the little arrow in the upper right corner of each element and choose floating only. you can arrange your workspace the way you want. But all your elements will not be docked. It doesn't really matter. But you have more control of what you workspace looks like. I admit each time I forget the proper way to dock the items because there is an underframe that is also off kilter. Another guru will need to help with that part. In the meantime. floating panels work for me.
Boni
nerd posted Sat, 29 August 2020 at 7:08 PM Forum Moderator
Use the UI memory dots. I always keep the first dot for each room set to factory. Then I set the next dot to my preferred layout. With the memory dots it's always 1 click to fix the layout.
Boni posted Sat, 29 August 2020 at 9:03 PM
Wow, thanks nerd!
Boni
