RAMWorks opened this issue on Aug 29, 2020 ยท 21 posts
RAMWorks posted Sat, 29 August 2020 at 8:22 PM Online Now!
Hi,
How does one hook up translucency using the Physical Surface Node? I don't want to use Cycles and I'm not crazy about the Poser Root node for what I'm trying to achieve and I think the Physical Surface Node is next to try.
Would I hook into the Transparency node? Makes no sense to me as when I put any value in it the object begins to fade out so can't be right.
Thanks for the help!
Richard
---Wolff On The Prowl---
hborre posted Sat, 29 August 2020 at 8:41 PM Online Now!
IIRC, translucency is akin to specularity but don't quote me on it. Unfortunately, Physical Surface Node has no provision for a direct translucent node. What are you trying to achieve?
infinity10 posted Sun, 30 August 2020 at 1:58 AM
You need to plug in an Image node which has your transparency, and switch the transparency on. There is also a coloured transparency option. I am using the Physical Root Surface with transparency effects, so it works.
Eternal Hobbyist
hborre posted Sun, 30 August 2020 at 7:20 AM Online Now!
@ infinity10: RAMWolff is inquiring about translucency and its relationship to the Physical Surface Node, not transparency.
EClark1894 posted Sun, 30 August 2020 at 8:20 AM
hborre posted at 9:12AM Sun, 30 August 2020 - #4398113
Here's the difference between transparent and translucent: When light encounters transparent materials, almost all of it passes directly through them. Glass, for example, is transparent to all visible light. Translucent objects allow some light to travel through them. Materials like frosted glass and some plastics are called translucent.
As for the Physical Surface node in Poser, you can plug the Translucent node into the Volume node connection. In fact, in many cases with Poser, the nodes will only allow you to plug into the correct connections. Here's an example: You want to plug the Translucent node into the Physical Surface Root node. But if you'll notice all the connections are greyed out except volume.
RAMWorks posted Sun, 30 August 2020 at 9:13 AM Online Now!
Thanks so much Earl. That was what I think I'm looking for. So TranslucentBsdf node plugged into Volume!
bagginsbill posted Sun, 30 August 2020 at 9:28 AM
You cannot plug Bsdf nodes into the Physical Surface. It has all the various node types you need built in.
Translucence is a hack, to be used with one-sided objects. For things that have a properly enclosed surface, you use scatter. And scatter is fully built into the Physical Surface node.
If you intend to use one-sided props, then you're not "physical" - such a thing is a fiction and requires the fictional "Translucence"
bagginsbill posted Sun, 30 August 2020 at 9:30 AM
By the way, BSDF stands for bidirectional scattering distribution function
bagginsbill posted Sun, 30 August 2020 at 9:31 AM
RAMWolff posted at 10:30AM Sun, 30 August 2020 - #4398145
No - that is nonsense. Like saying your recipe calls for apples roasted by burning oranges.
bagginsbill posted Sun, 30 August 2020 at 9:33 AM
The volume input is for volume scattering and attenuation - i.e. the alteration of light rays as they pass through a colored medium, like oil, colored glass, or coffee, or a liquid or gas with particles suspended in it like smoke, fog, etc. The latter is a phenomenon that includes scattering but not from "solid" things.
RAMWorks posted Sun, 30 August 2020 at 10:42 AM Online Now!
What I'm experimenting with is skin. Since I'm still trying to figure out things in Poser and have a character that just needs really nice skin I've tried just about all I can to try to achieve as realistic as I can. I don't want to use a canned solution and I know you make some great shaders Baggins but I don't learn by just click and apply, I need to know what I'm doing but I also have an old brain so pointing me to really technical pages to read through will really mess me up! LOL So if I know of the nodes that are more designed for skin, where to plug them in and what settings are generally used will give me a BASE to work from!
EClark1894 posted Sun, 30 August 2020 at 12:17 PM
bagginsbill posted at 1:14PM Sun, 30 August 2020 - #4398149
Someone should tell the Poser engineers that Poser is allowing something that can't be done. Sorry Ted, I checked before I posted that image. As you can see in the screen image, the volume connection is NOT greyed out, and I had just disconnected that input to show that Poser would allow it.
EClark1894 posted Sun, 30 August 2020 at 12:30 PM
bagginsbill posted at 1:28PM Sun, 30 August 2020 - #4398148
So what do I do? Believe BB, or my own lying eyes?
hborre posted Sun, 30 August 2020 at 12:32 PM Online Now!
Sorry, EClark1894. I just checked that in the material room, the PhysicalSurface still shows all connectors available in the presence of only the TranslucentBsdf node. Reboot your system and try again.
hborre posted Sun, 30 August 2020 at 12:34 PM Online Now!
The connectors gray out when the node is selected but it does not prevent you from connecting to other channels. Try it.
hborre posted Sun, 30 August 2020 at 12:44 PM Online Now!
As a matter of fact, put any cycle Bsdf node and all the channels except for Volume will gray out.
RAMWorks posted Sun, 30 August 2020 at 1:26 PM Online Now!
SO until I can get this figured out I'm going to fudge a bit and just use the default L'Homme skin settings but what I'm noticing in those settings is a fine layer of stippling on the skin after a render. Is there a way to get rid of that? I want the skin to look natural and this makes it NOT look natural. I've only had to adjust tiny bits here and there but I did notice this with the default textures plugged in so it's in the settings themselves! I think the lighter skin maps (default) didn't show these as much but now with my Gino face plugged into the face and lips it's quite obvious!
hborre posted Sun, 30 August 2020 at 2:13 PM Online Now!
Longer render time or your render settings need adjustment.
RAMWorks posted Sun, 30 August 2020 at 2:32 PM Online Now!
RAMWorks posted Sun, 30 August 2020 at 6:04 PM Online Now!
OK, got some acceptable render settings, the render takes a might longer but the results are acceptable! Good actually! Wish Poser had iRAY option! That would be nice!
bagginsbill posted Mon, 31 August 2020 at 6:35 AM
When I say "you cannot plug X into Y" I am not telling you that you will be physically stopped from making that connection. I'm saying it won't work. You cannot get the effect you want by doing that.
The Poser engineers made a bug there - the Volume input should only let you connect volumetric effect nodes, or Mixes or Adds that only carry volumetric effect nodes.
