Forum: Vue
Subject: Suddenly the transparency maps don't work...
RAGraphicDesign opened this issue on Sep 02, 2020 ยท 4 posts
RAGraphicDesign posted Wed, 02 September 2020 at 7:18 AM Online Now!
Hi everyone. Lately, when I import Poser files into Vue10 Complete (both pz3 files and obj files exported from Poser) the transparency maps no longer work. They have always worked. I initially thought the problem was because I was using Poser 11 and not Poser 9, but unfortunately that's not the reason. To do a further test I loaded a sphere with a basic white color and applied only a transparency map from a "hair" package. I see transparency in the nano-preview and in the preview, but when I go to render the sphere is rendered without any transparency map. I haven't changed anything in the basic settings ... I'm desperate :(
My Freestuff
martial posted Wed, 02 September 2020 at 7:39 AM
I have Vue infinite 2016 and transparency works on Poser 11 imported files Sorry cannot test with Vue 10 ,Examine the material setting
RAGraphicDesign posted Wed, 02 September 2020 at 8:20 AM Online Now!
I did further tests. The setting I've always given to my renders seems to be annoying for Poser files.. Now I have copied some render settings directly from those called "Final" and it seems to work. I don't understand this change of behavior by Vue anyway.....
My Freestuff
Atalantia posted Wed, 02 September 2020 at 8:28 PM
  1. Did you check in the Render Options if "Re-use indirect lightning" is deactivated. Alternative you can check in the menu Render, "Update indirect lightning next time"
  2. Check the checkbox "Force use of reflection map" also in the Render Options.
