Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Subject: Is this the latest up date Poser/ How do I get Queue Manager to work
saibabameuk opened this issue on Oct 02, 2020 ยท 7 posts
saibabameuk posted Fri, 02 October 2020 at 5:14 AM
Is this the latest up date Poser/ How do I get Queue Manager to work?Latest-Poser.jpg When will the next update be available if this is the latest up date.
raven posted Fri, 02 October 2020 at 7:58 AM
It should be in the render settings. Click on the button labelled 'Send Render To' and select Queue. That should then send the render to the Queue Manager.
hborre posted Fri, 02 October 2020 at 8:05 AM
There shouldn't be an update. Poser 12 is just around the corner to be released later this year. Version 11.3.818 is the latest build available. Describe exactly what you want to accomplish with Queue Manager? It is simply one of the render options available to you. Like render in background, it makes Poser available for further asset tweaking while rendering. If you have a second computer, you can farm the rendering process to it freeing up your resources on the primary machine. The network rendering works fine for Firefly, not for Superfly.
saibabameuk posted Fri, 02 October 2020 at 9:06 AM
Ok thanks for the info. I am working on PNG at present so should be able to use the info.
HartyBart posted Fri, 02 October 2020 at 9:38 PM
It can also be accessed from the top menu.
saibabameuk posted Sat, 03 October 2020 at 4:42 AM
Hey guys thank you, will be looking into this. Can I ask you whilst your on the thread together. I have completely forgotten how to post to my gallery . Yes I know its dumb question can you help? oppsWalk2102020.0043.png
raven posted Sat, 03 October 2020 at 10:16 AM
Hope this helps. Click on Galleries at the top of the page and in the menu select 'upload your art'.
