Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Subject: Any way to save out JUST a Layer in the Material Room?
RAMWorks opened this issue on Oct 14, 2020 ยท 6 posts
RAMWorks posted Wed, 14 October 2020 at 11:30 AM
Just as the subject line states. Wondering if I can save out just a layer.
So say you want to create an eyeliner in a new layer and want the user to have the option to apply that or have a REM file to remove it. I see no way to do that in Poser with the current save to library options.
Thanks for the help!
Richard
---Wolff On The Prowl---
My Store is HERE
My Freebies are HERE
structure posted Wed, 14 October 2020 at 1:00 PM Forum Coordinator
select your material - select the layer - select all the nodes on that layer
then save the material with the following setting.
Locked Out
RAMWorks posted Wed, 14 October 2020 at 6:01 PM
Hi, Thank you. BUT I was referring to the LAYER option in the Material room. Is there way to just save that Layer or do I have to say save the Head Map to have the Layer_1 saved with it or does it even save?
My Store is HERE
structure posted Wed, 14 October 2020 at 7:28 PM Forum Coordinator
that is for the layer option in the material room.
afaik it is the only way to save a layer out without a script.
Locked Out
infinity10 posted Wed, 14 October 2020 at 8:24 PM
I have not been able to save layer 1 or higher as separate material shaders. Only Layer 0 gets saved. You need to re-create the Layer 1 shader as a layer 0 on some other geometry (like a primitive pp2), then manually create a layer 1 on the target material zone and then copy the shader over from the primitive pp2.
This is a very clumsy shortcoming of the existing material room.
Eternal Hobbyist
RAMWorks posted Thu, 15 October 2020 at 9:32 AM
Ah, OK! Thanks so much folks!
My Store is HERE
