americanChi opened this issue on May 15, 2001 ยท 2 posts
americanChi posted Tue, 15 May 2001 at 9:04 AM
What is the best way to make a cr2 file, for poser to use. Using a existing obj file. So I can have the texture and morphs already on the character.
SAMS3D posted Tue, 15 May 2001 at 9:32 AM
Attached Link: http://www.sams3d.com
First of all, when you save your file as a .pz3, a cr2 is created, also when you save your object to one of the libraries you will create a .cr2, but if you want to edit it that is a different story. Example of way you can do it: Start with obj file, create a texture map with Steve Cox's UVmapper, save obj file in geometry file, open file with PhiBuilder, arrange your tree save phi file, open poser, go to file, and then convert heiarchy, find your saved phi file you then create a new figure, double click your new grey square and your figure should appear. More detailed instructions give me a shout. I really should know what kind of object you are trying to create a cr2 file for, is it a posable object that you are trying to create? Sharen
